I'm looking for a LM3875 headphone circuit - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 18th November 2007, 08:37 AM   #1
Default I'm looking for a LM3875 headphone circuit
I wolud like to create a headphone amplifier with LM3875. (32 ohm as output or more)
Can you please give me a diagram?? Or waht i have to change from the gainclone standard circuit??
TKS
Old 18th November 2007, 10:48 AM   #2
Paswa is offline Paswa  India
Paswa's Avatar
Hey, LM3875 for headphone? it is a 56WATT AUDIO AMPLIFIER. It'll certainly destroy to headphone and your ear. Don't make it. Look for headphone amp ICs like http://www.st.com/stonline/stappl/pr...n=&applilevel=
Old 19th November 2007, 12:33 PM   #3
h3ad is offline h3ad  Australia
i agree LM3875 is 2 LM3886's in the 1 package
unless u are extreemly deaf it is not advisable or u could give yourself seriouse hearing damage... even 1W into headphones is extreemly loud, let alone ~60w x 2
Old 19th November 2007, 02:59 PM   #4
Paswa's Avatar
oh, serenella, became mad? don't make it, it'll cause serious injury to your hearing organs
Old 19th November 2007, 05:37 PM   #5
No, it's not.
Depends on the headphones really I think.
Take a 600R set of headphones that need 1W for, say, 100dB. 1W in to a 600R load needs to swing... 24V ish, and so I would think an LM3875 would work quite well for that.
1W in to a 32R set of headphones, with 1W giving 120dB, however, would only need to swing around 5v (but would 'consume' more current), and I imagine you would be looking at somewhere between 1/4 to a 1/3 on the volume control for some extreme loudness, depending on the source and gain etc.
It won't just dump 60W of power in to the headphones regardless.
Old 19th November 2007, 06:00 PM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Yes, most of the above suggestions are simply misleading.
LM3875 will work very well as headphone amp without any modifications needed: LM3875 as a headphone amp (another try)
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
LM3875 as a headphone amp (another try) rjm Headphone Systems 16 20th February 2011 05:20 PM
Thoughts on circuit (IGC Lm3875) vindicare Chip Amps 0 10th June 2004 08:26 AM
LM3875 Amp/ Headphone Amp and USB DAC edpgc Headphone Systems 19 14th April 2004 04:09 PM
Q about LM3875 circuit... Buhl Chip Amps 1 12th December 2003 12:49 PM
A way to match two LM3875 for a parallel circuit? NoKnowledge Chip Amps 15 2nd October 2003 07:54 PM
Copyright ©1999-2017 diyAudio
