| Headphone Systems Everything to do with Headphones |
#21 | |
About 25 yrs ago I designed and built a wonderful sounding (well I thought so at the time.. ) Once repaired this amplifier worked flawlessly for >20yrs until I tossed it a couple of years ago as space was getting to be at a premium.. (i.e. Nothing inherently wrong with the design,) Caveat emptor as the Romans would say.. YMMV, etc..
www.kta-hifi.net |
#22 |
Odd you should mention fire...
Many years ago (before I was aware of the distinction between resistance measured by a multimeter and resistance measured by a high voltage tester), I made a pair of electrostatic headphones. Each driver was essentially two plates of perforated steel with a bit of cling film between them. A few bits of plastic clamped it all together and a pair of piano wires and a scrap of old jeans formed a headband. The plates were capacitively coupled to KT66 anodes. Insulation between the audio and ears was 1/2" of acoustically transparent foam (tested with aforesaid multimeter). They worked very well, although none of my friends would wear them (even before they caught fire while I was wearing them).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#23 |
Yep, the high voltage is a concern alright. I was actually going to build the 24V aikido as I had most of the stuff excluding boards, tubes and chassis. i was going to use BUF634 on the output. In any case I went the other route. Still curious as to how it would have sounded - my 24V aikido preamp is excellent.
| Tube Headphone Amp | sorenj07 | Swap Meet | 6 | 12th February 2008 02:35 AM |
| Octal tube as headphone amp output tube | yagoolar | Headphone Systems | 6 | 25th November 2006 09:11 PM |
| Tube Headphone Amp ! | -_nando-_ | Headphone Systems | 5 | 3rd April 2006 11:06 PM |
| My new tube headphone amp | MCLL | Headphone Systems | 7 | 24th July 2005 08:44 AM |
| How to use one tube instead of another in this headphone amp? | Pentium100 | Headphone Systems | 5 | 17th January 2005 03:00 AM |
| Page generated in 0.06714 seconds (78.15% PHP - 21.85% MySQL) with 10 queries |
