By piecing bits and pieces together, and reading many sources I've come up with a design which seems to simulate ok. I was hoping to get any thoughts about it people may have, and improvements, or why it is so terrible before I purchase components to try it out.
The schematic can be found here
Cheers.
Cheers.
You don't have any provision for adjusting the output stage bias. Why not replace R12 by a pot (say 220R).
Nothing is shown for trimming the offset.
You have no bias path at the input, so you absolutely require a DC coupled source, and must never power this up with the source disconnected.
You are running over 30mA through the LEDs, and I think that is a bit on the high side. You could replace R20 by either a higher value, or slip in a CC diode - say a J511, to get some extra PSRR.
No HF compensation is shown, and I don't think this is likely to be stable without it.
You might also want to consider putting emitter degeneration resistors into the input pairs, to bring the open loop gain down.
A Classic pitfall circuit
the bias in the VAS is not firmly fixed by this circuit and may vary with component tolerance from simply nonfunctional to self-destructive extemes
http://www.diyaudio.com/forums/showthread.php?s=&threadid=16796
a possible solution:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=56860
but I usually dismiss the diff complementary front end as little more than "eye candy" having little advantage in audio amplification
many headphone amp designs are collected at
http://headwize.com/projects/index.htm
