Headphone Systems Everything to do with Headphones
Suggestion for Headphone AMP with MUTE
Old 12th September 2007, 08:45 AM   #1
-_nando-_ is offline -_nando-_  Brazil
Send a message via MSN to -_nando-_ Suggestion for Headphone AMP with MUTE
Exclamation Suggestion for Headphone AMP with MUTE
Hi Folks !
I'm using two LM1875 to drive three headphones, they are connected to the chipamp trought a 51R resistor each one, and the amp performance with Headphones is wonderful ! BUT...
I MUST have mute function. When the system starts, the circuitry makes noise, so the microcontroller must control the MUTE of amps, with a little delay on power. The power amp have it, and what should be a good replacement for Headphones amp with mute? No problems with LM1875 performance.
The amp will run on + / - 15v.
Thank you very much !
Best regards
Suggestion for Headphone AMP with MUTEHide this!Advertise here!
lm3886 no mute rtill Chip Amps 21 29th August 2009 05:43 AM
Mute Point Anthony Dockril Chip Amps 8 28th November 2005 10:45 AM
Mute resistor value Lico Chip Amps 3 4th February 2005 04:40 PM
please help - no mute but did mute mod - tda1541 loomis Digital Source 1 14th November 2002 10:54 AM
lm3886 mute LED blabley Solid State 1 30th May 2002 05:51 AM
