Discrete simple headphone amp
I already posted it in the chip amps section, but I didnīt have too many helpful answers.
So could someone please comment on this circuit? here +-9V, 16-600ohm load thanks |
Looks like it needs a bit of work.
You should probably have a zobel on the output. Don't forget to use compensation on the NE5534, I would use the NE5532 instead. You don't need driver transistors. Here is a headphone amp from an older top-of-the-line McIntosh preamp. http://i56.photobucket.com/albums/g1...eitsch/C32.jpg It looks a bit like the AKSA power amp without the outputs. |
I don' t need too good amp, I need only something cheap (I will make 4 stereo drivers) with enough power and voltage for wide range of loads, and not as bad as LM386.
Driver transistors are the 2N..? I simulated distortion, and it came out better with them. The choose of transistors is because I have enough of them from some recent project, but will BCxx and BD139/140 make a difference? And what about TL072 instead of the NE5534/2? What values of zobel do you suggest for headphones? |
For reference...
A project something like your project: http://headwize.com/projects/showfil...=eaton_prj.htm The circuit diagram from that project: http://www.headwize.com/images/eaton2.gif Other interesting reference projects: http://headwize.com/projects/index.htm |
I just found out that my behringer mixer uses two 4580s + 100ohms paralleled for headphone out, so I guess almost anything will be better than that.
"The choose of transistors is because I have enough of them from some recent project, but will BCxx and BD139/140 make a difference?
And what about TL072 instead of the NE5534/2?" The 5534/32 sounds quite a bit better in the mids and bass than the TL07X opamp in this circuit. "What values of zobel do you suggest for headphones?" It has nothing to do with the headphones, it is for amplifier stability. I generally use 0.1uF and 10 ohms. The Eaton2 looks like a good project. The MJE243/253 are much better devices for outputs than the MJE340/350. |
Suggestion: use an off the shelf buffer like an LT10 or similar if you want something simple with good performance.
Take a look at the LT website. |
No LT10 or mje243/253 in here :(
Use what you can get, the MJE340/350 are good up to about 100mA when warm.
Should be good for over 120dB on most headphones. |
Try 2SB647/2SD667 too.
| All times are GMT. The time now is 12:47 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright Đ1999-2013 diyAudio
