Headphone Systems Everything to do with Headphones
Please help me debug my Headphone Amplifier
Old 7th August 2007, 09:56 AM   #1
rhavecilla is offline rhavecilla  Philippines
Send a message via Yahoo to rhavecilla
Unhappy Please help me debug my Headphone Amplifier
Attached is the schematic I used.
My problem are:
1. Hissing with or without input signal.
2. Clicking when I turn the input signal's volume to 0.
Thanks.
Why can't the tester test itself?
Old 7th August 2007, 10:33 AM   #2
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Hissing may be from the source. Do you use PCB or a test board. You may check the signal path if its too long...
Adiditonally if you hear some 100Hz noise then that means you have a ground loop. Yhen you must check your GND connections.
And your "click" noise comes from a bad GND connection.
However, I afraid TBA2822 is not a suitable IC for headphone applications. Its not HI-FI, it has a fixed gain which you will never need with headphones.
TDA1038 is a better alternative for that application. But I dont know if its still available or not.
Best regards,
Ozgur
Old 7th August 2007, 11:15 AM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
The amp is totally wrong for this. The gain is 100 but 2-4 is more what you'll need so noise is what you'll here! Use an opamp instead, maybe with an output buffer. Check my QRV02 for inspiration.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 18 pcb's in interest.
Old 7th August 2007, 12:06 PM   #4
Dxvideo's Avatar
Or you may have a look my last SE headphone amplifier. Which I currently use..
http://www.diyaudio.com/forums/showt...7&pagenumber=2
Its sound is fantastic.
Best regards,
Ozgur
Old 8th August 2007, 10:00 AM   #5
Thanks guys.
I found my fault. Since I am prototyping, this is my second attempt actually, I failed to use separate grounding for the input. I fixed it and it is now working noice free. I also added 100 Ohm in series with my headphone so to avoid clipping.
You guys are right. TDA2822 is not for the job. It is better than my first prototype based on LM386. But both can't deliver hi quality sound.
I will work on my next prototype and I will consider your seggestions here.
Thanks.
Old 8th August 2007, 10:07 AM   #6
Guys,
I've checked your suggestion. The design is awesome, but they are not portable. I need an Amplifier that can be powered by battery to be mobile. I will be using it to power my Sennheiser HD-201 and the source will be my iPod.
Thanks.
Old 8th August 2007, 05:22 PM   #7
jcx is offline jcx  United States
looking at other successful projects might help:
http://headwize.com/projects/index.htm
http://tangentsoft.net/audio/
Old 10th August 2007, 03:22 AM   #8
It's a OPA2227 based amp. I would love to do it but I can't find that chip here in the Philippines.
Please help me debug my Headphone AmplifierHide this!Advertise here!
Help debug my site zivyp Vendor's Bazaar 0 3rd February 2009 11:09 AM
help debug regulated psu milen007 Parts 16 5th October 2008 06:29 AM
Tedelex PSU debug Nordic Power Supplies 3 4th February 2006 12:17 PM
Introducing Debug Radio debugradio Introductions 1 3rd December 2004 08:20 AM
How to debug tweeter tomchaoda Multi-Way 1 7th March 2004 04:58 AM
