| Headphone Systems Everything to do with Headphones |
#41 |
Yes Its swinging between -4 to 0mV while pot is moving.
Is it bad?
Best regards, Ozgur |
#42 |
only 4mV swing with vol pot adjustment is very good. Many amps swing as much, or more, just from temperature effects alone.
regards Andrew T. |
#43 |
And these are the final situation of the amp... Enclosured and tested..
![]() ![]() ![]() Not beatifull but works.. The trimpots are from old design. Not connected to anywhere bur I didnot remove..
#44 |
How does the heat get out of that plastic box!
regards Andrew T. |
#45 |
We will see... I am not sure because I've tested it outside the box until now. May be I will drill some dirty holes upside..
| Class A Headphone Amp | solid | Headphone Systems | 10 | 8th May 2009 10:12 AM |
| TPA6120A2 Headphone Amp Offset Problems | cynric | Headphone Systems | 4 | 10th July 2007 09:42 AM |
| How much DC offset allowed in headphone amp? | jwb | Headphone Systems | 2 | 5th August 2003 11:15 AM |
| Page generated in 0.08036 seconds (65.64% PHP - 34.36% MySQL) with 11 queries |
