DC Offset on Class A headphone amp. - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 9th July 2007, 03:06 AM   #31
Originally posted by juergenk
it is still missing the coupling cap, without that the bias wouldn't work
I think my edited schematic doesn't need a coupling capacitor.
I don't see why it doesn't work.
Old 9th July 2007, 06:48 AM   #32
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Dear Zing,
Your "edited" drawing is same as my first circuit exactly. If you examine my first drawing, you'll see.
Anyway, It already works fine with that situation (and I cannot understand how?) , yes I feel some treble weakness but I hear no distortion or noise.
Best regards,
Ozgur
Old 9th July 2007, 01:50 PM   #33
Juergen Knoop's Avatar
because of the feedback, opamps output is a zero impedance dc-source, the 100R resistor does not help
only a cap could isolate the bias circuit from the opamp
it works for ac, but it does not work for dc
which you have recognized yourself
regards
Old 9th July 2007, 02:16 PM   #34
AndrewT is online now AndrewT  Scotland
it might help understand what is happening if you use the standard rule for opamps:
the output tries to settle at a voltage so that the two input pins are at the same voltage.
Now working back from that statement.
If the two input pins are both at zero volts, then you can work forward through the resistors to calculate what DC voltages need to be at the various points to get the circuit to be DC stable.
This will result in the output cap sitting at -Vgs.
If instead you work backwards from the output and assume zero volts at the source pin, then what voltage will appear on opamp pin2. Now using that same rule what voltage must pin3 be biassed to? This can be done with three resistors and a DC blocking cap.
Once you understand what the circuit is supposed to do then it becomes easier to design it to make it do what you need.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th July 2007, 02:35 PM   #35
Thank you, juergenk!
I misread R1 as 100k without thinking of such a high resistance would cause HF roll-off back then. What a fool! :0)
Old 10th July 2007, 06:30 AM   #36
Dxvideo's Avatar
Hi all,
I am fixed the unadjustable bias problem. Its now +4v and the offset on output is about 0v.
But now I have the unstability problem. DC offset voltage always swinging. I wait until the MOSFET comes to 55 C for bias adjusting. However while the temperature was stable output DC offset was still decreasing. And I had to put the 1500uF on output again.
But the sound is beatiful. No noise or distortion. The mids and trebles are very detailed. And the basses are impressive!
Best regards,
Ozgur
Old 20th July 2007, 03:02 PM   #37
Dxvideo's Avatar
This is the last situation of the circuit;
It works fine and HOT! But there is -2mV offset on each channel after warming up.
Do you think that make problem?
Best regards,
Ozgur
Old 20th July 2007, 04:13 PM   #38
2mV is an excellent result. Well done.
Does it hold steady as you alter the volume pot?
regards Andrew T.
Old 21st July 2007, 06:44 AM   #39
Dxvideo's Avatar
Hmmm... Good question. I havent tried that! I dont hear any noise while volume adjusting via pot. However technically, I am changing the input load and I have DC coupling so it must be changed.
I will test that.
Thx Andrew
Best regards,
Ozgur
Old 21st July 2007, 06:50 AM   #40
Dxvideo's Avatar
Sorry for double posting.
Best regards,
Ozgur
Class A Headphone Amp solid Headphone Systems 12 16th February 2013 04:41 AM
TPA6120A2 Headphone Amp Offset Problems cynric Headphone Systems 4 10th July 2007 09:42 AM
How much DC offset allowed in headphone amp? jwb Headphone Systems 2 5th August 2003 11:15 AM
Copyright 1999-2017 diyAudio
