Headphone Systems Everything to do with Headphones
How to connect 62 ohm headphone to 8 ohm output
Old 12th June 2007, 06:39 AM   #1
Sunsun22 is offline Sunsun22  Hong Kong
Sunsun22's Avatar
Default How to connect 62 ohm headphone to 8 ohm output
I just bought an AKG 701 headphone and want to use it with my tube amp (6BQ5 PP) that only has 8 ohm output terminals. Do I need another transformer?
Thank you
Old 12th June 2007, 06:48 AM   #2
joe carrow is offline joe carrow  United States
Send a message via AIM to joe carrow
Your other option, and there might be a good reason why this is a bad idea, would be to use a power resistor network to limit the maximum voltage to the headphones. Chances are you won't want more than a fraction of a watt to go to them anyway, so the wasted energy shouldn't cause any harm.
Old 12th June 2007, 08:58 AM   #3
Sunsun22's Avatar
Yes, this option is also in my mind but what would be the value of the resistor? I don't think this is as simple as 62 (impedance of AKG 701) minus 8 ohms because it is impedance, not resistance.
Old 12th June 2007, 12:14 PM   #4
Lord Winter is offline Lord Winter  Serbia
Lord Winter's Avatar
You may find this useful. Same trouble in the neighborhood.
Link
- I say let the Lord be our shield!
- The only shield I see is the one coverin' yer eyes.
Old 12th June 2007, 12:44 PM   #5
Hatti is offline Hatti  Germany
Resistor parallel to headphone:
1/8 = 1/62 + 1/x
1/x = 1/8 - 1/62
x= 9,185... Ohm 2 Watt will be enough, if your Amp only get 1.
If you have much more Power, you have to use a bigger (Watt)resistor.
The most power will go through the 9,185 (9,2) Ohm Resistor.
If this will be enough, to protect your headphone, you have to look!
cheers, Hatti
The step from genius to crazy, is very small! Please call me crazy, so I donīt have to declare!
Old 12th June 2007, 02:05 PM   #6
AndrewT is online now AndrewT  Scotland
a 10r or 9r1 resistor in parallel with the 62ohm headphones will load the Tube stage correctly.
But it still lets full output voltage to be fed to the headphones.
I would prefer to see a series & parallel combination to both load the output stage to match the 8ohm tapping AND reduce the voltage fed to the phones.
regards Andrew T.
Old 13th June 2007, 12:41 AM   #7
Robert McLean is offline Robert McLean  Canada
Default resistor network (L pad)
What I do is put 8 ohms in series and 1 ohm in parallel. The net result is not exaclty 8 ohms but so what. Your speakers are not exactly 8 ohms either. You could use 7 ohms in series but I dont have that value of resistor. You can also calculate the exact values to use to maintain a specified overall resistance for a specified attenuation ( ie an L pad ) but for this application great accuracy is not required. Depending on the sensitivity of your headphones, and of your ears, you may want to tweak the value of the parallel resistor by listening tests.
Robert McLean
Old 13th June 2007, 01:04 AM   #8
rdf is offline rdf  Canada
rdf's Avatar
I agree with Robert's recommendation because it also lowers the static noise floor to your headphones. One expansion, if it's a triode-connected amp I would experiment with higher value resistors. The lighter load on the amp will result in lower distortion. Pentodes need the load though.
Ears aren't microphones.
Old 13th June 2007, 01:33 AM   #9
Sunsun22's Avatar
Thank you for all the responses. It looks like resistor is the solution and I'll go ahead to try. Does any resistor work better than others?
Is there any good transformer available to solve this? What about a transformer that has a primary of 8 ohms and a secondary of 62 ohms? What about a transformer that matches the output from the PP 6BQ5 with a secondary of 62 ohmes? Are these transformer available in the market (e.g. Lundahl or Jensen?) or it has to be specially made?
To Robert,
A question about the connection. 8 ohms in series and 1 ohm in parallel will means the headphone is now having (62+8) ohms in parallel with 1 ohm. It doesn't sound right? Isn't it?
Old 13th June 2007, 09:26 AM   #10
1r0 //62ohm ~=0r98
amp sees 8r0+0r98~=8r98
The headphones look back and see 1r0//(8r0+Zout),
since Zout is fairly low the source resistance seen by the headphones is ~=0r89
The voltage felt by the headphones is approximately 0r98/(8r98)=0.109 (-19.2db). This is potentially very loud. A 10W valve amp will still send 100mW to the headphones.
regards Andrew T.
How to connect 62 ohm headphone to 8 ohm outputHide this!Advertise here!
Add headphone output to preamp whitelabrat Headphone Systems 2 24th January 2008 08:36 PM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 04:19 PM
Headphone Output to GC amp StalfoS Headphone Systems 10 29th March 2005 01:08 PM
Can i connect directly DIR1701 DIN to cd-rom,Sb live s/pdif output azyx Digital Source 2 28th March 2004 02:04 AM
What output Z for headphone amp? jeffreyj Headphone Systems 29 13th August 2003 11:28 PM
Copyright ©1999-2017 diyAudio
