Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 4th May 2007, 08:11 AM   #1
Shoog's Avatar
Default Idea for an ECL82 PP headphone amp.
Hi their all,
After my last power amp upgrade I have a few ECL82's which are now redundant. I currently have a parafeed partial feedback ECL82 SE headphone amp, but my last experiments have show the weakness of this valve in this circuit. So I was thinking of a new PP headphone amp.
The idea is to use the two triode section of a pair of ECL82's to drive a microphone line driving transformer in parafeed. This steps down the voltage gain of the triode by 10x which should make it more reasonable to deal with the excessive gain. It will also do the phase splitting for the two triode strapped pentodes. The phase splitting and output stage is old hat and I can cope with that. What I want to know is how best to set up the two triodes to give the best drive to the microphone transformer.
I originally thought of using them in an SRPP, but after reading the TUBECAD article, I realise that this is a totally inappropriate application for them. Of course I could just parallel them - but this risks imbalance blurring the signal - seems to be a poor choice - better to stick with a single triode and let the other go to waste.
The question is does anyone have any good ideas how to get the best out of a pair of triodes as a driver ?
Shoog
Old 4th May 2007, 09:38 AM   #2
mostly thinkerer
Hi Shoog
Only thing I can think about is a MU stage with one triode as driver and the other as load. But I doubt if that helds any benefit.
Actually I am replying with a question on your planned use of the microphone line driving transformer. I have seen several microphone tranformers, but they can all handle just a couple volts AC, maybe 2 or so. Will you be using one of those?
Erik
Old 4th May 2007, 10:24 AM   #3
Shoog's Avatar
That was the idea. Unfortunately its just an idea. as you well know it might not work in practice. I hadn't really though about the voltage limit !!
Shouldn't be to difficult to lash up and might just work. I will let you know.
Shoog
Old 4th May 2007, 10:35 AM   #4
owen is offline owen  United Kingdom
Ahh the choices...
You could 'equal load' the triode using a low VA dual primary torroid - one primary in the anode circuit and the other primary in the cathode. Top off with a smallish R to provide Bias (remember it has to be the same top and bottom, and you have a nice PP stage, with balanced out.
Or
Operate the triodes in inverted mode, feeding the pentodes - hammers thier high gain, and provides lots of current drive for CMiller (which is low anyway, because it's a 'tode) - They can be fed from the transformer further upstream, where you're unlikely to encounter saturation issues
Or
Use one triode as a CCS on the second triode to linearise the curves, take a parafeed output to a TX that drives the pentodes
Or
use the 'tode as a CCS for the triode, operated in inverted mode - drive as a PP pair to a transformer
Or
use the 'todes as a CCS for the triodes, operated normally with a cathode follower output
Or, or, or
see, lots of choices
Owen
Old 4th May 2007, 11:07 AM   #5
Shoog's Avatar
Sounds promising.
However if I put the phase splitting TX before the triodes, I would have a step down situation and would need quite a lot of gain to drive the pentodes. I would guess that I would need at least 20x gain in this configuration. What could I expect from the inverted triode ?
Shoog
Old 12th May 2007, 11:50 AM   #6
Shoog's Avatar
This is my latest thinking.
Use the microphone transformers at the input to phase split and step down. Send the split signal to the triodes (in normal mode) and have them as a LTP with both inputs driven by the transformer. Use this to directly drive the triode strapped pentodes.
The question is a) will this work b) will a 1K cathode resistor be sufficient for the LTP's cathode load. If not can anyone suggest a 2mA CCS for the job.
Shoog
Old 12th May 2007, 12:22 PM   #7
mostly thinkerer
Hi Shoog
From theory both your ideas would work, off course. But, as you have had good experiences driving the 6AS7 in differential modus, I would try to use a CCS for the triodes to (although the resistors would also work, as the phase splitting is done by the transformer).
When you came up with the transformer idea, I remembered this
thread by Stuart. I forgot to post it, but now that your thread popped up again...
Erik
Old 12th May 2007, 04:13 PM   #8
Shoog's Avatar
Interesting thread. Unfortunately implementing it would involve stringing an order together - which I am reluctant to do.
I was thinking of a single resistor in the tails of the two triodes - so combining transformer phase splitting with a conventional differential stage as well. The transformer should reject input noise/ ground loops, and the LTP should reduce heater hum at the sensitive input stage, as well as correcting for transformer inbalance. The question is would the performance be significantly improved by replacing the single resistor with a CCS ?
Nice theory at least.
I was thinking of going differential on the outputs as well - but I think it might not be necessary.
I was talking to Jkeny about the possibility of using this as driver stage for a bigger output stage. Getting the benefits of transformer phase splitting on the cheap. The only issue would be implementing gNFB.
Shoog
Old 13th May 2007, 10:09 AM   #9
mostly thinkerer
Hi Shoog
This is probably the difference between 'working' and 'working and fantastic sounding', but, which is which?
Knowing you, I am sure that at the end you will try all those different possibilities (and report us about them).
And now, a bit off topic, about the MOT. I was seeing another thread that talked about the use of a PP tranny in a SE amplifier with a CCS taking cara of 'nulling' current in the OPT. Seeing the MOT thing, I though something similar could be applied to it, passing a current through the 220V (primary) to cancel the magnetising effect of DC through the secondary. I do not know how to calculate, but it could work, improving the inductance...I think
Erik
Old 13th May 2007, 10:28 AM   #10
Shoog's Avatar
I saw this discussed somewhere else. In the end I concluded that sometimes a square peg is a square peg and shouldn't be forced into a round hole. I think parafeed is a more elegent solution to to a similiar problem.
The MOT's make reasonable chokes but they are big and heavy. Its the secondary that does the choke duty. The problem I could see would be setting the current through the choke - how would you do it without a CCS?
Shoog
ECL82 Headphone amp mod_evil Headphone Systems 9 8th April 2007 10:31 PM
Ideas for using a pair of ECL82 in a headphone amp. Shoog Headphone Systems 60 5th November 2005 10:26 AM
Headphone amp idea.... robselina Headphone Systems 23 27th May 2005 06:43 PM
OTL 6L6 headphone amp-idea+need help trespasser_guy Headphone Systems 16 25th March 2003 01:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
