| Headphone Systems Everything to do with Headphones |
I got bored and started noodling around in LTSpice. At first I was simulating the usual buffered opamp, using 2 diodes for bias, something like ESP's Project 113. Then I decided to try out diamond buffering. I came up with this: ![]() Pretty basic I think and seems to sim well, but I'm not a great expert on designing amplifiers. Any experts out there care to tell me what they think? I was even thinking about trying it out using BC850/860 instead of BC546/556, but i'd have to get some of those... |
#3 |
True, ideally I want full swing with a 1V RMS input signal. It's easy enough to change R6 though.
edit: I set R6 to 3K and that does the trick. It still seems stable but I dont think the model of the OPA(2)134 is particularly good in that regard. |
#4 |
Electrons are yellow and more is better!
The output stage will run in almost class B.
Forget about the cascodes in my design. Check which values the emitter resistors have.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#5 |
Hi Per-Anders... I must say I've seen your boards and they are works of art
Sadly I'm just a home hack, doing my boards in a tray of sodium persulfate being warmed in a bath of heated water.. I haven't tried anything double sided yet as I havent worked out a good (cheap) way of doing vias.I am guessing the cascode stages are T3/T7, and T14/T4/T8. What purpose do T1 and T2 serve? I am guessing they act as references in the current mirror. I had thought about emitter degeneration and will probably add it as it makes the PCB easier to construct into the bargain. The output is class AB but only just, there is about 18mA of bias according to the sim. Class A would be better though, especially at this low power. |
#6 |
The design looks nice, and I'd be curious if it performs as well as the sim. No reason it shouldn't. Long ago I did a class A headphone amp I really liked, though the design was a bit unorthodox. It was basically an op-amp driving a power FET, but with a separate op-amp/FET current source underneath. The interesting thing about that is the output of the op-amp runs at the gate voltage of the FET. Thus, until you reach fairly high levels, no zero crossing occurs in the op-amp- it runs pseudo class A as well. The thing sounded great, and I can probably dredge up a schematic if any body's interested, though you'll likely be a bit skeptical at first
#7 | |
#8 |
Yeah, I was concerned about thermal stability. Not sure how to go about that one yet. I might try and put it together with some parts I have laying about, on a piece of veroboard or so.
As you said, the sim doesnt tell the whole story. |
| Another DAC + Headphone amp | ghetto | Digital Source | 14 | 10th July 2008 04:02 PM |
| Using a headphone amp as a pre-amp? | Basalt | Solid State | 4 | 19th November 2007 09:55 AM |
| ESL Headphone X-former | bjackson | Planars & Exotics | 5 | 19th September 2005 03:45 AM |
| Headphone amp | audioPT | Headphone Systems | 3 | 20th September 2004 10:17 PM |
| Zen v4 headphone amp | Rob M | Headphone Systems | 11 | 21st May 2003 12:58 AM |
