ODAC - general and technical discussions ODAC - general and technical discussions - Page 9 - diyAudio
Go Back   Home > Forums > > >
Head 'n' HiFi - Walter At Head 'n' HiFi we will provide you with the finest Audio equipment and parts for a reasonable price. We will also host Group Buys on request, this includes production of PCB's from our trusted manufacturer and sourcing of the parts at lowest prices. We also have manufacturers for enclosures and panels at hand. Once we host a project we will re-stock it frequently depending on demand, you will never miss out on a project again.
Old 4th January 2013, 02:10 PM   #81
swalter is offline swalter  Switzerland
Default Problem with Raspberry Pi
Below has just been posted as review on my web page, thought I share it here as well
Stefan
Bought at the end of the year, super packaging, fast delivery, very nice contact with Head n Hifi staff.
Tested on two different devices with different software configurations:
#1: regular HTPC, intel USB controler.
"bit perfect" playback (mpd configured to bypass the sound software layer) > no problem (16 and 24bit)
Software mixer (e.g. re-sampling of the audio flux to 16bit/44.1kHz). > no problem
#2: Raspberry PI
"bit perfect" playback > the output sound is sizzling, it seems that the PI's USB controller can't handle the ODAC (same result in 16 and 24 bit)
Software mixer > no problem
In all the cases where no problem was encountered the sound quality is great, I can hardly tell the difference between the ODAC and my DACMagic.
Set up with a Rasberry PI, as I can tell I didn't yet manage to use the full 24bit capabilities of the ODAC in this setup, but the output sound is still actual "CD quality" (e.g. 16bit 44.1kHz) with software re-sampling.
everything O2 and ODAC related can be found here: www.headnhifi.com - your DIY and audio resource
or have a peek in our vendor forum: http://www.diyaudio.com/forums/head-n-hifi-walter/
Old 4th January 2013, 07:57 PM   #82
captain pugwash is offline captain pugwash  United Kingdom
Been using the odac for about a month now and very impressed! I use it with Foobar and wasapi on a Win7 PC. With Foobar (preferences - output - output format) and the odac (control panel - sound - properties - advanced) both set to 24 bit (or any other combination for that matter), the Windows volume still works, I had expected this not to be the case as wasapi by passes the windows controller, has anyone else experience of this?
Old 14th January 2013, 03:33 PM   #83
TheShaman is offline TheShaman  Europe
Got the extra panel today. Thanks for the great service, Stefan! Appreciated!!
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 14th January 2013, 05:28 PM   #84
bart_dood is offline bart_dood  United States
Stefan
Hi, Do you have any info on connecting the ODAC to the raspberry pi? I would like to do this using XMBC or perhaps wheezy. I couldn't find the post you quoted.
Thanks!
Old 14th January 2013, 05:47 PM   #85
Thanks!
Hi, the quote above is copied from my website and was posted as review from one of my customers.
From his experience the Pi is not able to handle the ODAC with bit perfect output settings.
16bit CD quality seems to work fine with it.
Best Regards, Stefan
Old 30th January 2013, 09:18 AM   #86
darksky is offline darksky
I want to share my experience with odac. I bought odac to drive my power amp and floorstanding speakers. I have tested it with my notebook and brother's. Everything was working OK and sound was very good, compared to notebook integrated crap sound. I decided to connect odac to my girlfriend HP notebook. The sound was very distorted. I didn't understand why.... I have done a lot of google search to find out, why it sounds so bad. The problem was here:
What Is the AMD USB Filter Driver? | Tech Tips - Salon.com
Maybe this information willl help for others, who has notebooks with amd chipsets and has distorted sound with odac. Usually amd usb filter is installed when you buy new notebook with factory installed OS and drivers, and you won't have problems with odac, but I always do clean install to get rid rubbish software which installed by manufacturer. So don' forget to install amd usb filter if you also do clean instal.
Old 13th February 2013, 06:00 AM   #87
miero is offline miero  Czech Republic
The notebook issue can be caused by its switched power supply. I tried USB DAC with ASUS low-end notebook and then connected to desktop speakers. The interference was so high that it was not pleasant to listen to anything. I've tried to replaced power supply with the one from old Thinkpad and the distortion has disappeared.
Old 13th February 2013, 10:00 AM   #88
If it's your reply to my post, I don't agree with you. The problem is only amd chipset, which manage all usb hubs in computer. I also must say that amd usb filter driver still didn't solve completely the problem. After installing driver, distortions became much lower, but I can still hear some. Maybe the newest version can solve the problem, but HP support gives only one old version and you can't download the latest driver neither from amd webpage or from other laptop manufacturer, because driver is individually written only for concrete model. My suggestion is to forget any usb dac, if you need to install amd usb filter driver. Before buying usb dac, I'm recommending to check your laptop model support webpage and search for amd usb filter driver. If you found such, don't buy usb dac, if you don't want surprises. In such situation maybe firewire, spdif will be better connection choice.
I'm not the only one :
USB Audio problem HP 6735s laptop - Page 2 - HP Support Forum - 21803
Old 13th April 2013, 10:40 PM   #89
JZatopa is offline JZatopa  United States
Originally Posted by DJNUBZ View Post
I have somehow blown out my odac. It looks like the part labeled fb102 has burnt out. Could someone tell me what this piece is?
Fraggler did you find a fix?
I replaced fb102 and it didn't fix anything. I also noticed that ESD1 and ESD2 are missing from my board. The replacement I just got has something in both of them. Any ideas what they are? could I just short them and see if I get anything?
Old 24th September 2013, 02:28 PM   #90
runeks is offline runeks
I just received my ODAC in the mail and I've been testing it against an internal Terratec Aureon 7.1-Space sound card in my PC, connected to a NAD C 352 amplifier with a pair of B&W DM603S2 speakers. I can't hear a difference. Not that I necessarily expected to; one of the reasons I bought the ODAC is to avoid the loud sound output by the analog out of my sound card when my computer is turned off. Also, it makes me able to have devices without a sound card output sound to my stereo.
One thing that disappointed me though was the noise floor. It's exactly the same as that of my internal sound card.
When nothing is playing on the ODAC, it's silent. Probably because it's not outputting anything. But when I play a WAV file with silence in it, its noise floor goes up to exactly that of the internal sound card. The noise floor of the internal sound card is the same whether I play anything on it or not though.
Interestingly, when I connect the ODAC to my Raspberry Pi, the noise floor disappears almost completely. So as far as I can deduce, noise is being transferred from my PC over the USB cable to the ODAC.
ODAC - general and technical discussionsHide this!Advertise here!
ODAC - European and Worldwide pre-orders swalter Head 'n' HiFi - Walter 215 8th March 2017 10:31 AM
ODAC offerings from Various Vendors swalter Vendor's Bazaar 216 15th April 2013 03:53 AM
Class D discussions mskeete Class D 16 19th March 2004 06:27 AM
Discussions on Balenced Amplifers theChris Chip Amps 24 6th January 2004 02:40 PM
Copyright ©1999-2017 diyAudio
