| Head 'n' HiFi - Walter At Head 'n' HiFi we will provide you with the finest Audio equipment and parts for a reasonable price. We will also host Group Buys on request, this includes production of PCB's from our trusted manufacturer and sourcing of the parts at lowest prices. We also have manufacturers for enclosures and panels at hand. Once we host a project we will re-stock it frequently depending on demand, you will never miss out on a project again. |
#11 |
#12 |
Got my Odac in from JDS labs today...
Had a bit of a hard time installing it, it was actually easy, but there was no instructions and very little to no info online on how to get it up and runing. Im posting this to help others.. Basically 1. Do not remove battery terminals, I desoldered mine, then realized they are supposed to stay. 2. Cut 2 traces under PCB: ![]() 3. Solder Wires, from LR Line out on the Odac to P1 input on O2. Left is first hole closest to PCB, Middle is Ground, 3rd hole is right channel. I just "bridged" the 2 ground solder connections on the Odac and ran a single wire from there to the middle P2 hole. 4. use nut/bolt or, do what I did, a small piece of foam tape works perfectly, securely fashions the PCB, and is the perfect gap and lines up perfectly with the side grooves in the case. 5. re-assemble case and your done. |
#13 |
Is there a part number for the output jack for the ODAC listed anywhere? I suspect it is the same as the O2, but I haven't seen it specified.
Thanks for your time. -Aaron. |
#14 | |
life is beautiful...
3.5mm Digikey CP-3523SJCT-ND I will list them in my shop shortly as well. I also give them away as freebee wirh every ODAC ![]() Stefan
everything O2 and ODAC related can be found here: www.headnhifi.com - your DIY and audio resource or have a peek in our vendor forum: http://www.diyaudio.com/forums/head-n-hifi-walter/ Joachim Gerhard Filter Buffer Fastron Inductor and Parts GB - second run Google signup sheet here |
#15 |
#16 |
oh boy... this is a big one.
I had Foobar set to 24bit output Wasapi (Odac). But windows audio control panel was set to 16 bit 44.1, I noticed that windows volume control was still controlling Foobar even though it's set to wasapi. This is odd behavior, but more importantly it means that it's still going though the windows stack, which means that foobar's 24 bit output was getting resampled to 16 bit by the windows driver. I changed the windows options to 24-bit 44.1 and holy cow, what a difference, sounds like a whole new level of greatness. anyway, long story short, make sure Foobar and Windows audio settings are aligned, and why does it not bypass the windows audio completely? (Wasapi) this is with windows 7 64 bit. Foobar defaults to 24 bit, windows defaults to 16 bit, this IS IMPORTANT. big difference in sound quality. Last edited by Mweatherford; 26th May 2012 at 10:33 PM. |
#17 |
mweatherford
if you figure out how to bypass the windows stack, let me know -joe
our diyaudio forum - post your questions here Audio Poutine - full web site coming soon ODAC/O2 parts or assembled - Google spreadsheet |
#18 |
I have not spent much time trying to, to be honest, I was just surprised, as I have several other USB audio type devices and Dacs, USB SPDIF converters etc, and the windows volume control never works when they are set to WASAPI in Foobar. Im not sure it matters much, as long as they are aligned there should not be any resampling up/down etc by windows.
#19 |
Recieved my ODAC today. I must praise swalter for nice packaging and all communication.
This little thing is a beast. Beated my Audio-GD DAC easily. Much more air between instruments, very nice spatial information, more refined and natural sound. |
#20 |
Which Audio GD dac do you have?
| ODAC offerings from Various Vendors | swalter | Vendor's Bazaar | 216 | 15th April 2013 03:53 AM |
| ODAC - European and Worldwide pre-orders | swalter | Head 'n' HiFi - Walter | 202 | 25th January 2013 01:32 PM |
| Class D discussions | mskeete | Class D | 16 | 19th March 2004 06:27 AM |
| Discussions on Balenced Amplifers | theChris | Chip Amps | 24 | 6th January 2004 02:40 PM |
