Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 23rd May 2007, 10:19 PM   #41
Biggest problem I have with DIY is the sheet metal,
cases, covers, etc.
Still looking for something decent that doesn't cost
an arm and a leg,
Bob
Old 30th May 2007, 09:59 PM   #42
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Power transformers shipped today, waiting for them...
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 6th June 2007, 04:47 AM   #43
Wavebourn's Avatar
Arrived power transformers.
I expect drawings of chassis from manufacturer this Friday.
Do anybody volunteer to help me to draw PCBs using software?
Old 5th July 2007, 10:24 PM   #44
Wavebourn's Avatar
I got quotes for chassis' made in USA: $195 per chassis (plus shipment).
Who is in please let me know.
Anatoliy
Old 5th July 2007, 10:41 PM   #45
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
One for me!
Arne K
Ars longa, vita brevis
Old 5th July 2007, 11:22 PM   #46
Wavebourn's Avatar
Originally posted by Cobra2
One for me!
Arne K
Arne;
they will be bright red.
I've asked for a quote for some chrome plated, waiting for the answer..
The chassis contains holes for transformers, for 4 GU-50 tubes in thin sockets, for 2x 6N2P + 2 x 6N6P + 2 x 6E1P + one SG3S.
Rear panel: 2 holes for TRS inputs (or RCA may be installed for Hi End version), 6 holes for speakers (4, 8, 16 Ohm for each channels) - TRS (for Gih End Chinese golden-plexiglass bananas may be installed, for 4 and 8 ohm only), 2 fuses (anode and AC), and one AC plug (rectangular).
Front panel: 2 volume controls, 1 power switch, one power lock.
Perforated bottom cover
Also, I will order optional mirrors between GU-50 tubes and transformers, for better look and to protect transformers from IR radiation from tubes and front and rear false - panels with lettering. However, mine will have Wavebourn marked on them, so probably you will need to order some for your taste.
Anatoliy
Old 12th March 2011, 09:42 PM   #47
Hello Wavebourn
Did you order special transformer for these project or stock transformers from Edcor?
Please let me know.
I think It would be more interesting to try these project.
Of course I'm not in hurry, I just study which way to go.
You wrote GU-50 tubes are great.
I found some schematic at German website (That site it have some PC board lay out to..)but the power tube are powered under 400V.
Also I read your project , I like it, you use much higher voltage.
I will wait on your advise. If I invest a lot of money in the irons I want to be sure I can finish the project. Also I will register on your forum.
Cobra did you finished your amp??
First I have to finish some SS project.
Greetings gabor
Old 15th March 2011, 05:37 PM   #48
Wavebourn,
Are all of the transformers spoken for? If someone decides not to take there order please let me know.
Tad
Old 15th March 2011, 06:34 PM   #49
Hello
I would like to have a set transformer to.
Greetings
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 11:44 AM
Quad II power amps......power output transformers!!! bwes87 Tubes / Valves 3 10th September 2008 03:20 AM
Power Transformers in Output! mod_evil Tubes / Valves 17 25th May 2006 09:31 AM
Page generated in 0.10804 seconds (75.00% PHP - 25.00% MySQL) with 11 queries
