Not here yet, but it's 8:09 am in Chicago , I hope I'll meet those beauties today when the ups will show up.any ideas for the heatsink ?
Not here yet just a couple hours south of you. So at least I don't think it's an individual thing.
AndrewT,
I'm just happy I found them. I think they were pretty much the only option for heatsinks here that fit the board closely enough. The only other options I was finding was paying crazy money to have one shipped here from EU.
It was sent to your work address I'll believe.If destination means addressee, no. I've received nothing until now.
Micha
the ups just came, but no boards .
i hope tomorrow ill get them.
I am pretty much in the same boat with "Loafimus",
i am curious if he got them.
is FISCHER ELEKTRONIK SK 92/75 SA a good cooling solution or the Thermal Resistance is too high?
I think they'll come in USPS, not UPS.
Also, in a previous post I had a link to HeatsinkUSA. They have acceptable sizes for the build and can be cut to the height you want so it'll fit in your case of choice. for a 3U case, a 4" cut was perfect. The one you posted should work, but when I looked, it was crazy expensive to ship to the US.
usps i meant to say.
I see now those 4.600" WIDE EXTRUDED ALUMINUM HEATSINK. great!
I think you'll want one with a thicker base. I believe I did the 7.280". It looks like the 4.230" one has the same thickness base. I would wait until you get the board so you can measure to be sure.
Yes, that's right! I've double-checked the address at PayPal and it's correct. I hope the boards will arrive this week
Micha
if I remember the BOM correctly length shoud be 150 mm or 200 mm.
I think 75 mm is too small.
The Fischer SK92 150SA has a R(th) of < 1 K/W. Thats better than the Pada from the BOM.
SK 92, Standardstrangkhlkrper, Khlkrper f.cool, Fischer Elektronik
Which of the heatsink profile did you end up buying?Not here yet just a couple hours south of you. So at least I don't think it's an individual thing.
AndrewT,
Thanks!!
Thanks!!
I used the 7.280" - HeatsinkUSA cut to 4". Worked perfectly in a 3U case. I honestly think it may of been overkill and if I do it again will use a 2.5 - 3" cut and try to squeeze it in a smaller chassis.
Also, I mentioned it earlier, but the thread over in the ChipAmps forum has a lot of good information. My build along with a couple others are posted in it and it answered a lot of the questions I had.
http://www.diyaudio.com/forums/chip-amps/280949-newbee-build-pa03-amp-lm4780.html
Thanks for the info.I used the 7.280" - HeatsinkUSA cut to 4". Worked perfectly in a 3U case. I honestly think it may of been overkill and if I do it again will use a 2.5 - 3" cut and try to squeeze it in a smaller chassis.
I have some of the 5.375" but were cut to 8" long. Classic case of whatever you have never fits
Am I the only one who did not receive the pcb? I'm worried...
No, you're not alone.
Go into Paypal and check your shipping address. To me it looks a bit suspect. If we are lucky the letter will be returned after four weeks. The address goes to a shopping mall? (According to Google)Am I the only one who did not receive the pcb? I'm worried...
- Group Buys
- Pavel Dudek's super Gainclone group buy
