Group Buys Members group buys
GB -- "VU Meter Amplifier" PCB
Old 14th January 2008, 07:46 AM   #71
ckwong99 is offline ckwong99  Hong Kong
Hi Sklimek,
It's very wonderful thing but if it had passed your test will be fantastic.
Can you share the PCB layout with me ?
Or, if you have a more, how about sell one for me.
I have a pair of lager meter from Japan , not sure who have interest ?
CK
Old 14th January 2008, 02:13 PM   #72
sklimek is offline sklimek  United States
sklimek's Avatar
Hi CK, I did a quick hook up to the output of a of a CD player and and watched very small meter movement, the output was only .5 volt though. I need to wire it up correctly to see if it works correctly, I also need to figure out what my meters are and how to calibrate it as well. I'll try to get to it this later this week.
I made the circuit w/ Eagle, here is a revised .sch and board layout, keep us posted, thanks - Stan
Old 14th January 2008, 02:37 PM   #73
sklimek's Avatar
Screenshot of the schematic, let me know if you can use the eagle files.
Stan
Old 14th January 2008, 02:47 PM   #74
The passage claimed the first stage gain factors is 6. In general speaking CD player can deliver 0.5-1v rms output for this circuit. So that it can be operated in a larger scale.
http://www.edn.com/contents/images/6280030.pdf
From the passage said IC2 which monitors the difference between the incoming signal's amplitude and the peak-detected output. What is the meaning to this statement ? What the function of the IC2 ?
If you can find what the problem of your case, please update to me. Later, I will try to make one of this prototype.
SCH & PCB I am using Protel SE 99 , it really a good thing but eagle i can try. Can you post the PCB brd layout file here ?
Old 14th January 2008, 03:13 PM   #75
sklimek's Avatar
Here's the Eagle .brd file.
Old 18th January 2008, 01:59 PM   #76
comicrcc is offline comicrcc  United States
I am interested in your VU meter board also.
Old 22nd October 2011, 07:04 PM   #77
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Hi. Do you have a BOM that goes with the PCB design? Thanks...
Old 22nd October 2011, 08:26 PM   #78
sklimek's Avatar
Hi Sylvain, if you are referring to me instead of jackinnj sure I will post the BOM and latest .brd/.sch file when I get back home in about a week.
I recently reworked the board and had the same problem of no gain at the outputs. It would be great to have your eyes and brain on this to see where my problem is if you are interested.
Best - Stan
Old 25th October 2011, 01:26 AM   #79
sklimek's Avatar
OK, here is the latest version of the board. I attached the BOM, Eagle files and pics of the board.
This schematic was created from the original EDN article Volume-Unit meter spans 60-dB dynamic range scroll down.
As mentioned before I had gain problems on output.
Hope this helps…
Old 25th October 2011, 04:41 AM   #80
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
I'll jump on 2 sets of boards when they are ready.
GB -- "VU Meter Amplifier" PCBHide this!Advertise here!
8,8 meter basshorn "6090 Monster" Skramstad Subwoofers 150 1st September 2013 03:35 AM
Anyone know some decent free SPL meter software & "white noise"? Spasticteapot Multi-Way 18 6th October 2011 09:05 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Tube amp with "meter"? stl Tubes / Valves 9 4th February 2009 04:57 PM
