Group Buys Members group buys
GB -- "VU Meter Amplifier" PCB
Old 9th December 2006, 04:07 PM   #41
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Hello Jackinnj,
great idea for the project. I will be interested as well in getting a few boards. I hope they are going to be available soon.
I would like to know what type of meters we should be looking for? Volt meters, amp meters or specificly VU meters? I made some calls and learned that VU meters are built differently from lets say voltmeter or amp meter in the terms of ballistic - the way needle moves and speed. Logically VU meters would be best, but I would conclude many people will try to use what they have or eBay where not soo many VU meters are available, so it will be very helpfull to know what to look for. If voltmeter or amp meter is OK what maximum Voltage or Amps they should be made for?
I also would like to know if it is possible to convert or use your boards as a Wattmeter, as I am planning in using it on the amp. In my mind VU meter and peak meter are much more usefull in the preamp area so in the amp wattmeter would be great.
Here is a good resource for new meters in US:
http://www.meterdistributor.com/index.htm
I spoke with tech support and they are great to deal with.
I am lookingg for BIG meter, something like 6" wide, so all that I am finding are meters for hunreds of Volts or Amps. I would appreciate your guidance on this subject very much.
Thank you
AR2
Old 10th December 2006, 04:47 AM   #42
Master Burner
AR2's Avatar
Here is the meter for serious analog meter lovers.
Old 10th December 2006, 12:46 PM   #43
Nordic is offline Nordic  South Africa
Nordic's Avatar
If I understood correctly that circuit would use a 10V meter.... as it could provide an improved scale compared to a UV meter.
Old 18th December 2006, 12:15 AM   #44
sts9fan is offline sts9fan  United States
i would like some of these as well
Old 18th December 2006, 12:21 AM   #45
davidlzimmer is offline davidlzimmer  United States
I much prefer an analog meter as oppossed to a digital or LED indicator. Mainly becuase of the natural damping.
But, I'm old and slow.
Poor stereo mix? Switch to mono! Perfect.
Old 18th December 2006, 03:02 AM   #46
Master Burner
AR2's Avatar
I hope Jackinnj is out of his jam at work. Jack I sent you email with some questions, and I do not know if you have received it.
I decided to go ahead and order parts so I could do assembly point to point. I will order smaller meter just for testing and than if it works well I will go for big one.
In submitted article, it is mentioned that this volume meter is meant to be used with typical 100 W amp. What if amp is much bigger? Do we need to add some voltage divider or that could be done through the circuit, or meter should be changed for higher voltage.
Does anyone knows what replacement diodes to use instead of ones in schematics:
D1 MBR0520 and D2 CMPD6263S? These are surface mount and I would like to substitute them for through hole for point to point wiring.
This would be a really good project for surface mount devices, as the size of board could be much smaller, and there are really not too many parts.
AR2
Old 18th December 2006, 03:16 AM   #47
Master Burner
AR2's Avatar
Sorry disregard my question on various amp power. Jackinnj explained it on first page.
Old 2nd January 2007, 09:26 AM   #48
Master Burner
AR2's Avatar
Unfortunately not too much activity in this tread.
I completed this circuit by doing point to point wireing on small proto board. I got small 10V AC Voltmeter just for testing purpose. The circuit works well, but I am not sure that meter is the right choice. I still have to calibrate meter for the max and min movement as explained earlier by Jacinnj. The movement is what I am not too happy about. Niedle moves rapidly, and is very sensitive (easily reaches max) but has a lot of inertion. That results in the niedle rocking left and rigt with no signal until it setles. I do not know if the problem is that voltmeters are not made to have a fast movenmet and maybe I would need VU meter to test.
If anyone else made a test please post your experience, partcularly on meter movement.
Thank you
AR2
Old 9th January 2007, 04:18 PM   #49
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally posted by AR2
Niedle moves rapidly, and is very sensitive (easily reaches max) but has a lot of inertion. That results in the niedle rocking left and rigt with no signal until it setles. AR2
Are you using the value of inductor specified.
The logjam at work is now managed.
Jack
Old 9th January 2007, 04:23 PM   #50
Master Burner
AR2's Avatar
Yes I do - 10 mH
GB -- "VU Meter Amplifier" PCBHide this!Advertise here!
8,8 meter basshorn "6090 Monster" Skramstad Subwoofers 150 1st September 2013 04:35 AM
Anyone know some decent free SPL meter software & "white noise"? Spasticteapot Multi-Way 18 6th October 2011 10:05 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Tube amp with "meter"? stl Tubes / Valves 9 4th February 2009 05:57 PM
