Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 31st July 2006, 08:28 AM   #1
Luck is offline Luck  China
Send a message via ICQ to Luck
Default Project Tube and ic amplifier PCB or kits
I have a project using tube 6922EH(OR ECC88)as input buffer,
LM1875 as power output IC..I had finished the engineering working sample. You can get more information in AMP Chip ......
Now i am going to make a update version of the PCB, who is interesting in this project? I think the price of all the materials in the PCB will be controlled under 40$ including the tube,ic,and heating.......
Hope more froends will join in this project....
Old 31st July 2006, 08:32 AM   #2
Thumbs up some reference schematics
here are some reference sch...
Old 31st July 2006, 08:33 AM   #3
Default another SCH...
ANOTHER ONE...
Old 31st July 2006, 08:35 AM   #4
Default My engineering working sample
My engineering working sample.....
Old 1st August 2006, 02:54 AM   #5
Default Here are some pictures of the PCB with components
Here are some pictures of the PCB with components. The PCB size is 20*15cm, 1.6mm FR4 material.
The tube we can use 6922EH or 6DJ8 or ECC88 or E88CC or 6N11......
Old 1st August 2006, 02:59 AM   #6
Smile picture of the tube
picture of the tube .....below the tube is LM7806 for heating the "lamp" inside the tube.
Old 1st August 2006, 03:06 AM   #7
Default The relay part using LM7812
The relay part using LM7812 , when power on, the relays will be conected after around 10 seconds......during this 10 seconds, LM7806 is working and heating the "lamp" inside the tube...
Old 1st August 2006, 03:09 AM   #8
Default LM1875 IC
using two LM1875 IC for power ouput.....20W+20W power can be output when connected with 8_ohm impendence speakers...
Old 1st August 2006, 03:12 AM   #9
Default The rare side of the PCB........
The rare side of the PCB after soldering all the components.
Old 1st August 2006, 03:21 AM   #10
Default about the power supply
About the power supply:
20V~-----0V------20V~ 3A is suggested for LM1875.....(120W)
18V~-----0V------18V~ 3A can also be used in this case.
12V~ 0.5A is for the relay part. (6W)
8V~-----9V~ 1.0A is for the "lamp" inside the tube.(8W---9W)
So, the power of the transformer shall be around 150W in this case.
Raphaelite Audio Transformers & Sino Tube Amplifier Kits - What's your experience ? kimbal Tubes / Valves 7 14th September 2010 08:50 PM
S-5 tube amp kits blacksquirrel Tubes / Valves 7 3rd June 2008 01:10 AM
Audio amplifier project kits syber Chip Amps 2 6th December 2006 07:42 PM
The Next Step. (and budget tube amplifier kits/designs). percy Tubes / Valves 15 18th August 2004 07:45 PM
Page generated in 0.11626 seconds (76.23% PHP - 23.77% MySQL) with 11 queries
