Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 14th January 2007, 03:51 PM   #81
BobEllis's Avatar
Mouser sells the Wima FKP2s, there must be another distributor on your side of the world.
I like the sound of polyprops better than polyester, not that I have done a direct comparison. I've heard that the FKP (polypropylene film and foil) sound better than the MKP (metalized polypropylene film), but I haven't used them yet.
Polystyrene and Teflon are supposedly the holy grail. Mouser has some polystyrene caps that I used in a crossover. They are cheap, have 2 mm lead spacing and are only 10% so it was buy a big batch and sort. I was surprised how tightly they grouped, mostly within 1% of each other, but 5% off specified capacitance. This is my best sounding crossover to date, but I went from ~LR4 with notch for woofer to 8th order initial rolloff Cauer at a lower frequency. Again, no direct comparison to the previous polypropylene version.
F1 Fan, thanks for the suggestion.
Old 14th January 2007, 05:10 PM   #82
F1 FAN is offline F1 FAN  Canada
Your welcome Bob,I should mention I used 24nf and 47nf from the 417 series for the filter sections.The 100nf has bigger spacing but the 416 series 100nf will fit.
I used the 100nf Panasonic ECQ stacked films for the bypass caps.Digikey part P4525-ND
Old 15th January 2007, 12:52 AM   #83
tcpip is offline tcpip  India
Originally posted by AndrewT
what use have you in mind that requires Q<0.5?
Basically, I've done paper designs of many active xo's by taking their passive xo's and trying to convert them to active with exactly the same phase and SPL curves. I have found that this can be done, but after optimising the curves, I get filter stages with very strange Q sometimes. Omitting those stages is not an option; I get clearly unacceptable levels of phase errors.
During these experiments, I've seen that Q < 0.5 often occurs in one of the stages. That's why I was asking.
For a report of one such experiment, see here. In this example, there was no low-Q stage, but in other cases, it's happened.
Old 15th January 2007, 12:58 AM   #84
Originally posted by F1 FAN
Hi tcpip,I used the BC components MKP 417 series 2% polyprop
available at digikey.They fit the board perfectly.
Yes, those were the closest fit among the ones I found. Thanks for the confirmation.
Thanks. I'll check Mouser. Let's hope their Website will be easier to use than the nighmarish www.mcminone.com --- that's easily the worst online retailing electronics components Website I've seen.
I like the sound of polyprops better than polyester, not that I have done a direct comparison....
Thanks a lot. I'll keep these in mind. Of course, actually selecting caps for any project may be influenced more by size than type, given this tight-fit board.
BTW, how do you design your active xo's? Do you use SoundEasy, LSPCad or some similar package?
Old 15th January 2007, 01:33 AM   #85
BobEllis's Avatar
When it comes to hobby software, I am a tightwad. I use Speaker Workshop to measure in the cabinets. Then I use an eyeball approach to add a little higher Q to compensate for a droop near the crossover and vice versa. I get the impression that Linkwitz does it this way. So I figure with careful measurement and willingness to go a few iterations, I can get pretty good results, too.
Notches and shelving are done the same way. Baffle step is almost a textbook thing, although I tend to reduce it if the speakers will be close to the wall. I use "The Edge" for predicting baffle step response.
I build the XO, measure and tweak from there. Tweaking will be a lot easier now that I have a few of Jens' active filter 2 boards running. Nicely adjustable, with a prototype area that I have populated with sockets for adjustable notch filters.
SWCad from Linear is a nice free program that allows me to verify my spreadsheet calculations. It is particularly handy when doing Cauer filters.
It would be nice to have software to predict off axis response, but measure/tweak/repeat gives satisfactory results. Besides, for me much of the fun is the building. Wouldn't want that to go too fast. In some ways I get more satisfaction out of an unsuccessful experiment - it makes it easy to justify the next project. Thank goodness I only have my bank account to answer to.
Old 9th February 2007, 05:44 PM   #86
I'm more than a bit late in joining this GB... I would be greatful if any of you have a board or two to spare... Pls let me know..
I'm not sure if it is too much to ask, but if Jen or Bob could be kind enough to send me a pdf of the pcb layout, I could try to etch one myself though I would much prefer to have a professionally made board.
Old 30th April 2007, 10:32 AM   #87
I'm, also interrested in a pair of PCBs. Any chance there's someone out there with a soft spot for a fellow DIYer?
THNX
/Frez
"I never forget a face, but in your case I'm ready to make an exception."
Active XO board group buy BobEllis Multi-Way 0 21st February 2006 09:29 PM
Generic active filter / crossover... board... thingie... JohnR Parts 5 14th October 2002 10:13 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.11387 seconds (78.90% PHP - 21.10% MySQL) with 11 queries
