| Group Buys Members group buys |
#21 |
AmpsLab are using TDA7250 in there amplifier. Maximum output current is quite similar to LM4702... 5mA
http://www.ampslab.com/tda7250cfp.htm |
#22 |
I agree that an emitter follower is indeed an appropriate solution, but I was hoping for something a little more elegant. I was leaning toward a complimentary feedback pair, but I was a little hesitant since I would like to add a few more pairs of transistors to the output stage to make it capable of driving harder loads, and I haven't quite gotten the "triple" CFP to take multiple output transistors. I know that this is not a new problem, nor have I really tried hard to get it to work, so I guess I just haven't gotten it to work YET!
Edit: Woopsie! Looks like I didn't take a close look at the schematic. |
#23 |
This output has intrigued me - I may try it. The negative thermal coefficient of the lateral mosfets helps keep them thermally stable.
http://www.ne.jp/asahi/evo/amp/J49K134/report2.htm |
#24 |
OR perhaps the 2sk215/j78 driving transistors?
#25 | |
#26 |
#27 |
We ordered some from you,Do you have a board layout for the dracula amp?
#28 |
What do you think of using this type of output
#29 | ||
Fast GB: LM4702 high power amp test board ;) I think that Sziklai style output section can be a good choice - but first I wont to try MOSFETs here... They can be placed into my board without any modifications. |
#30 |
| FAST high-side drivers/circuitry? | mzzj | Power Supplies | 20 | 23rd December 2005 09:33 PM |
| how to model fast high frequency op-amps | zilog | Class D | 0 | 28th November 2005 03:53 PM |
| Need help with tube test data - fast | HugoR | Tubes / Valves | 15 | 7th November 2005 09:24 PM |
| Fast High-End Design from Elektor May 1997 | JDeV | Solid State | 1 | 12th November 2003 03:43 AM |
| Page generated in 0.10207 seconds (77.44% PHP - 22.56% MySQL) with 11 queries |
