Group Buys Members group buys
Possible LM4702 PCB Buy
Old 3rd June 2006, 02:25 AM   #41
dfdye is offline dfdye  United States
dfdye's Avatar
One component I forgot to mention: RG should be a low value 1/2W resistor, either 0R or 1R. If you would rather take the signal ground directly to your chassis star ground, you can simply run an additional ground wire from the RG hole closest to the LM4702 chip (which is the signal star ground on the PCB) to your ground. Since the signal ground and power grounds will now be separated, I don't think you should have any problems.
I haven't had any problems using a 1R resistor for RG, but if you experience any hum this would be my first suggestion.
David
Old 9th June 2006, 02:06 AM   #42
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
David,
got my boards today, thanks a lot. do you have chips and parts you can sell me?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 9th June 2006, 06:18 PM   #43
dfdye's Avatar
I'm working on it. I think there might be a group buy on parts in the near future.
Old 10th June 2006, 03:06 AM   #44
dshortt9 is offline dshortt9  United States
dshortt9's Avatar
Got my boards. I'm in on group buy whenever.
Old 14th June 2006, 03:06 PM   #45
dfdye's Avatar
Brett, and others:
I am putting together a few brief comments and suggestions regarding the board and I should be done sometime this weekend. I'll put in some suggestions as to my favorite component configurations and a simple darlington output stage. Most of what I have been playing with lately has been based off of the new information from the National AN-1490 application note. Most of the suggestions they have in the note are easily implimented in these boards, but a couple of things aren't too obvious, so I want to make sure everything works before I tell others to try things!
Old 14th June 2006, 07:28 PM   #46
TonyTecson's Avatar
read the app note, but i do not agree with the groundplane thing, i have built lots of leach super amps with ground plane boards and never had issues with it.
Old 14th June 2006, 07:47 PM   #47
dfdye's Avatar
My logic on the ground plane was pretty specific: I wanted the signal grounds in a star configuration connected to a power ground plane via a resistor to avoid any hum while keeping the benefits of a ground plane. In my testing I haven't noticed anything goofy in terms of hum or anything. I still haven't done critical tests, but nothing has shown up on the scope.
David
Old 14th June 2006, 09:08 PM   #48
enzedone is offline enzedone  New Zealand
enzedone's Avatar
Default Star ground
I'm certainly no guru and no next to nothing about electronics, but I have always used a 1ohm and a 100nf cap from signal to power ground and never had any noise problems. I think it's really imortant just to make it that little bit more difficult for any dirty power to go through into any of the audio section.
Brett
I realized that a major part of my job was to figure out how to use technology control to create economic force, or leverage, such that money and business flowed in Microsoft's direction” — Alex St.John, father of DirectX.
Old 14th June 2006, 09:26 PM   #49
Upupa Epops is offline Upupa Epops  Czech Republic
I don't see power transistors there... Why ? It will cause again neverendig stream of questions, how you can make it ....
Old 14th June 2006, 09:42 PM   #50
enzedone's Avatar
Default Boards
David
Thanks for that link. It's good for plebs such as myself and interesting reading about grounding issues.
I think the biggets issue for me is also output stage as I'm no wiz. So this will be the scary point.
And also a good idea to have a group buy maybe. As for some of us it may be very difficult to obtain power transistors needed to get this puppy up and running.
And also, thanks for all the work you have put in so far. This project was on the brink of dying until you gave it a new lease of life
Cheers
Brett
Possible LM4702 PCB BuyHide this!Advertise here!
Lm4702 Mike Gergen Chip Amps 120 9th August 2017 02:32 PM
Lm4702 Bpa halo0925 Chip Amps 19 13th November 2006 04:47 AM
Lm4702 BPA halo0925 Solid State 0 9th November 2006 10:26 PM
Copyright ©1999-2017 diyAudio
