| Group Buys Members group buys |
#611 | |
I missed the 6VAC on your drawing... sorry.... you should watch the phase of your AC when you "add" them... I recommend thinking about the point of using a regulated supply for the front end that actually sits on something floating... I think a pure 70V supply for the front end is better? \\\Jens |
#612 |
Jens,
When adding auxiliary windings in a transformer to the main winding to achieve higher frontend voltage how do you determine the phase. In most cases the net voltage reading is all that is available. I too have looked into using the psu2.2 as a regulator for my leach amp. The net on the frontend would be approximately 82 volts. I am using a 12 volt auxiliary winding from the main 1 kva transformer. Tad |
#613 | |
The easy way, without a scope, is to look at the winding direction on the torride.... that will tell you the direction for the aux winding to work correctly. \\\Jens |
#614 |
@jens or bob,
can you again please post the schematics corresponding to the board v2.2 please? thanks....
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
#615 |
#616 |
Hi Jens,
thanks a lot, that was fast....
#617 | |
#618 |
Are there any boards left, and can this support +-18V 250ma ?
#619 |
Sorry for bringing this thread back into circulation. But I need some help if anyone is still reading this.
I have just started to build my 6 transistor Jens Rasmussen Leach amp (from 2005/6) and I was planning to use the PSU 2.2 unit (65V version) of this thread as my regulator. So I have a couple of questions to start with.
Cheers, Fred
Signature |
#620 |
1. 40 VAC gets you ~55V, which is appropriate voltage for the main supply, but not enough to get you to 65V for the front end. You might try a voltage doubler as shown in http://www.passdiy.com/pdf/a75p2.pdf to feed the regulator. If you want to go that route we can discuss how to create a doubler to work with with this circuit board. Otherwise, you could use a separate 50-55V transformer or add auxiliary windings to your main transformer to give you another 10-15 VAC.
2. If using a center tapped transformer, you must not use D2, D4, D12 and D14. Repeating that just because you didn't state it. A better grounding practice would be to return the center tap and the regulator grounds to a star ground, where you also connect the Leach amp's ground leads. |
| Zener regulator with "integrated" pre-regulator | 00940 | Power Supplies | 17 | 22nd July 2008 06:11 PM |
| Lithos regulator - A new super regulator? | peranders | Parts | 7 | 8th May 2008 03:01 PM |
| Scalable Power Supply GB | BobEllis | Solid State | 0 | 3rd April 2006 06:11 PM |
| Page generated in 0.18373 seconds (64.41% PHP - 35.59% MySQL) with 11 queries |
