| Group Buys Members group buys |
#41 |
would a series resistor after R4 junction feeding T1 emitter add a bit of current limiting in event of mishap?
regards Andrew T. |
#42 |
what is R2 doing? Is it something to do with start up?
regards Andrew T. |
#43 |
What are R3&R19 for? Isn't that a problem under transient conditions? They dominate the loop under turn on/off conditions.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#44 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#45 |
May I suggest soldering a resistor on the bottom side if extra trimming is needed
No point making a big problem out of nothing - IMHO \Jens |
#46 | |
#47 | |
#48 |
The 431 is out of the question as the voltage divider needed for low voltage references will raise the output impedance a lot (lower loop gain) I prefer the 10V LM4040 as this allows for a voltage divider with more gain compared to the 431 (2.5V) divider
The capacitor in parallel with the emitter resistor has been removed as I found it was not needed for stability. For practical reasons I have left it out as the cap needed to actually do any difference was so big (>100uF) that I chose not to bother Initially I wanted it to be there as a gain reducer at high frequencies…. I found it to be not needed and removed it. \Jens |
#49 | ||
#50 | |
\Jens |
| Zener regulator with "integrated" pre-regulator | 00940 | Power Supplies | 17 | 22nd July 2008 05:11 PM |
| Lithos regulator - A new super regulator? | peranders | Parts | 7 | 8th May 2008 02:01 PM |
| Scalable Power Supply GB | BobEllis | Solid State | 0 | 3rd April 2006 05:11 PM |
| Page generated in 0.12177 seconds (76.62% PHP - 23.38% MySQL) with 11 queries |
