| Group Buys Members group buys |
#31 |
no problem Kro - I just wanted to point out the "scalable" part of this project.
#32 |
Jens,
Could you pls include the component values on the schematic? Or maybe put it on the next page of the schematics. Thanks. |
#33 |
We're getting close to a final design.
Since you last saw it, Jens has added more output capacitance, screw terminal blocks for input and output, and the ability to split positive and negative supplies into two boards |
#34 |
Updated schmatics
\Jens |
#35 |
Top side
\Jens |
#36 |
And the bottom side
\Jens |
#37 |
Electrons are yellow and more is better!
Jens, an idea
not so smart now when you have put so much work into it... but... Why don't you make the pcb with a mirrored negative regulator so that the ground can be shared at the output? You can still make the pcb detachable. If you check my JSR06 PSU you can see what I mean. The advantage would be a true +-15 V PSU and in the same time to single boards.Notice that the groundplane is divided in sections. One more option would be having extra resistors for the feedback. Sometimes it's very easy just to solder one resistor in parallel to trim the voltage.
/Per-Anders (my first name) or P-A as my friends call me |
#38 |
Per,
I don't see the point in mirroring the layout, when I have two identical sections providing a positive and negative supply. I like mirrored layouts, but only when there is a need for it due to mechanical considerations or signal flow. The layout is as close to identical as possible as I have used complementary parts everywhere possible / needed. The gnd plane can be separated – no problem - I just thinks its going to be a forum decision so that most people will be happy with the choices made. I added a multi turn trimmer to make adjustment easier. An idea could be to piggybag the positive and negative supply to save space. \Jens |
#39 |
I ment if you have a 3-wire connection, the ground will go across negative regulator but if it was mirrored it wouldn't happen. Do you understand what I mean?
#40 |
Nice work Jens.
I have no problem running one more lead to my star ground if using a common ground has a negative impact on performance. I like the tripot idea. Question for buyers: Do we want a trimpot in the parts kit or just a resistor that will give very close to 15V? |
| Zener regulator with "integrated" pre-regulator | 00940 | Power Supplies | 17 | 22nd July 2008 05:11 PM |
| Lithos regulator - A new super regulator? | peranders | Parts | 7 | 8th May 2008 02:01 PM |
| Scalable Power Supply GB | BobEllis | Solid State | 0 | 3rd April 2006 05:11 PM |
| Page generated in 0.10021 seconds (78.22% PHP - 21.78% MySQL) with 11 queries |
