| Group Buys Members group buys |
#11 |
Still would like to see pass transistors on a single edge
advantages are many 1) wider variation of input voltages and transformer options 2) reduces cost of finding and purchasing 2 PCB heatsinks 3) Can use simple L bracket or even chassis mount
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#12 |
Electrons are yellow and more is better!
Nice work Jens
/Per-Anders (my first name) or P-A as my friends call me |
#13 |
Hi Per,
I only did some P-SPICE sim... Output impedance is about 0.250Ohm Stability is ok and so is speed 1A step response @15V out is included \Jens |
#14 | |
Steen
#15 |
#16 | |
Heat sinks are not needed for many applications. The WIKI will show parts kits and heat sinks separately. I'm thinking the parts kit will include: standard resistors (Xicon or Panasonic) Panasonic FC electrolytics (values TBD) polyester caps MPSA42/92 MJE15031/32 1N4007 1N5239 Comments on parts selection? |
#17 |
I added some a few extra parts to bring to the output impedance with a factor of 10 to about 25mOhm (@DC)
PSRR looks ok and stability is not an issue.... Work to come: Update/evaluate voltage ref to TL431. Look at snobbers... Carlos are you listening?? Change Terminals to something smarter Build ratsnest to test circuit and different caps (I might make room for some SMT ceramics) Updated the schmatics to latest version. \Jens |
#18 |
Would it be a good idea to rotate the component layout 90 deg on the board and put the output contacts in the same position as the power input on the filter boards?
Then it would be possible to piggyback the boards with short leads....
I don't suffer from insanity, I enjoy every minute of it! |
#19 | |
If you have room why don't you add SOT23 transistors also. There are many good SOT23 devices out there. It might also be an idea to have an extra LP-filter for the reference but this has also to do how much the noise is from the regulator itself. C13, C15 why? Don't you loose feedback in high frequences? Have you noticed that you have equally many parts as in a super regulator but it is still a discrete regulator. Snobber what is that?
#20 |
can someone update the Wiki. I have used the last blank line and reset the total to 125. Is the price coming down below $6 yet?
regards Andrew T. |
| Zener regulator with "integrated" pre-regulator | 00940 | Power Supplies | 17 | 22nd July 2008 06:11 PM |
| Lithos regulator - A new super regulator? | peranders | Parts | 7 | 8th May 2008 03:01 PM |
| Scalable Power Supply GB | BobEllis | Solid State | 0 | 3rd April 2006 06:11 PM |
| Page generated in 0.92913 seconds (9.72% PHP - 90.28% MySQL) with 11 queries |
