Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 13th June 2007, 02:24 PM   #301
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Modifying it would not be a problem.
I still need rough estimate how many boards are needed.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th June 2007, 12:12 AM   #302
Um ...
So what's going on ? We talking about an F3 group buy, or ZenV9 group buy ?
Old 14th June 2007, 12:44 AM   #303
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
Eh,how much difference?
Regards Åke
Old 14th June 2007, 01:55 AM   #304
Well what is the difference between the two ?
I've compared the schematics, but not in detail yet ...
I did like the ZenV9 layout
Old 14th June 2007, 02:09 AM   #305
luvdunhill's Avatar
Peter:
If you are indeed going to make the F4 changes, I'd be interested in whatever it takes to do a pair of monoblocks i.e. "100 watt balanced mono-block use" from the F4 Owner's Manual... I guess 4 amp boards and 4 power supply boards? Any idea of the cost yet, as perhaps I'd order some another set depending on the price
Old 14th June 2007, 02:48 AM   #306
The F4 boards info was posted here: http://www.diyaudio.com/forums/showt...25#post1231125
www.audiosector.com
Old 14th June 2007, 07:29 AM   #307
h_a is offline h_a  Europe
h_a's Avatar
The F3 is a tuned version of the Zen#9.
Nelson himself says
The two are very similar, and from the DIY perspective
the differences are not worth bothering about.
The F3 has some refinements more applicable to those
with sophisticated test equipment.
However I'm always a fan of improvements and better measurement results usually translate into better sounding.
Since the changes should be quite tiny I definitely opt for the F3.
Cheers, Hannes
PS: if you let me some time, I count the rough # of boards, Peter.
PPS: Hi Marc! Also keen on the F3?
Old 14th June 2007, 08:27 AM   #308
Well then count me in for an F3 stereo pair, and pair of PSU boards (1 board per channel, right ?).
Oh !
Will the boards be prepped for those fancy Jensen 4 pole capacitors ?
Old 14th June 2007, 12:47 PM   #309
h_a's Avatar
I'll come up to something like 40 full stereo pcb sets, however there might be already ones which already bailed out.
I setup a Wiki, so please enter yourself and express how many boards you want!
F3 PCB Group buy Wiki
Cheers, Hannes
Old 24th June 2007, 09:28 PM   #310
Fuling is offline Fuling  Sweden
I would like two amp boards and two PSU boards too, but I must be stupid cause I don´t understand how to add myself to that wiki-thingie
L/R Boards and Matched IRFP240 Boards for Aleph/ A-X lgreen Swap Meet 7 25th August 2009 04:56 AM
FS: Conrad Heatsinks;.... 'PASS' B1 boards w/JFETS;...... F4 AMP & PSU boards cowboy99 Swap Meet 5 25th August 2009 02:39 AM
Pass Aleph 1.7 boards, Zhaolu 2.5A, P700 VRDS, UGS PS boards, dac chips analog_sa Swap Meet 4 14th March 2009 05:29 PM
WTB: F4 boards Gluca Swap Meet 2 10th March 2009 07:49 AM
FT: Pass boards for P101 boards bjefferys Swap Meet 1 26th March 2006 07:39 PM
Page generated in 0.10643 seconds (74.75% PHP - 25.25% MySQL) with 11 queries
