Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 21st February 2006, 09:38 PM   #11
kro5998 is offline kro5998  Netherlands
I added my interest to the wiki.
I concur with Nisbeth on the all pass option.
An onboard PSU with LM3xx and room for the caps would be great.
KRO5998
Old 21st February 2006, 11:22 PM   #12
Even though I'm about to order my components for my stripboard crossover, this GB is likely to come in before I start soldering!
Could you maybe expand the wiki to explain what it is we are expressing interest in, ie what the current configuration is and what is being debated. And also how many are needed for typical configurations, as I'm a bit slow tonight.
For my 2-ways I want BSC, 4th order HP, 4th order LP, LT, 1xGain, and a notch/peak or 2. I think the board gives me everything but the Linkwitz Transform.
Can the all-pass section be used as something else instead?
Old 22nd February 2006, 10:05 PM   #13
gmikol is offline gmikol  United States
Wow...this looks great!! I had started to draw something like this up for myself, but Jens' design looks way better than mine.
--I also think that a 4th order allpass section should be included (though I realize that that requires 4 more opamp stages ... 2 more IC's.)
--A on-board PSU I could take or leave, I mean, you'll have a PSU for your amp, right?
--Is it possible to add resistive mixing of L & R channels to use this on a subwoofer, too?
Looking at the schematic, it looks like this is designed as a band-pass board. Is there any way to split out the HP and LP outputs so that the board could be used with both filter sections for one driver, or e.g. HP for tweet and LP for woof.
Potentially, this could reduce the # of boards needed for a project, no? I mean, tweeters generally don't need an LPF section, right?
I suppose if the boards are cheap enough it doesn't matter.
Just my humble $0.02
--Greg
PS -- I'll add myself to the wiki once I figure out how many I'll need.
Old 23rd February 2006, 12:04 AM   #14
When you split the HP and LP sections you lose the possibility of using it as a bandpass filter.
I would prefer one input buffer then splitting into two equal sections with EQ,HP,LP and output buffer.
All sections including the HP and LP Op-amps should be jumpered so you can chose between 2 th or 4 th order.HP,LP or BP with or without EQ.
I would also like the option of a input capacitor.
Just my preference though.
btw. is there a reason for using the input buffer for gain instead of the outputbuffer? 6 dB seems a lot, 2 or 3 dB should be more then enough.
regards.
kro5998
Old 23rd February 2006, 04:17 PM   #15
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Can somebody tell me if this is the sort of thing that I need for my new loudspeaker project ?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 23rd February 2006, 08:00 PM   #16
BobEllis's Avatar
Nuuk,
It really depends on what you need - Once the sections are split, it should handle dipole EQ (1st order Shelving Low Pass + a notch) and still do up to 4th order HP and LP, with an extra notch thrown in. To make the XO shown in your thread would take two boards per channel.
Of course the catch is that we have to sweet talk Jens into making these changes, since I am not able to do layouts. This started as Jens being bored and I semi accidentally I tried to rope him into doing a board for a group buy.
Keep monitoring this thread and see how the board develops.
Old 23rd February 2006, 08:41 PM   #17
Nuuk's Avatar
Standing by Bob!
Old 24th February 2006, 03:41 AM   #18
tg3 is offline tg3  United States
tg3's Avatar
I am also interested if it can do dipole EQ.
If you don't measure, you don't know.
Old 24th February 2006, 08:20 AM   #19
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
I will be "bored" again in about 4 hours
It friday - and I'm in love (The Cure)
\Jens
Old 24th February 2006, 12:47 PM   #20
I have decided to create this project in Eagle V4.14 light.
This means that anybody can edit the files for their later requirements because the free version of eagle can handle the board which is limited to 8 x 10 cm.
I will have room for about 8 to 10 dual opamps and their surrounding passive components + a +-15V power supply to drive the whole thing from any transformer (rectifier bridge on board)
May I suggest the following be considered?
1) Input stage (single ended or balanced what gain should it have?) I prefer single ended.
2) Number of filter sections (and outputs) and filter order
3) Number of EQ sections (What topology)
4) Output buffer
5) Anything else??
\Jens
Active filter board GB BobEllis Solid State 0 21st February 2006 09:30 PM
Page generated in 0.12034 seconds (86.81% PHP - 13.19% MySQL) with 11 queries
