Group Buys Members group buys
Aleph-X Compact PCB Group Buy
Old 6th February 2006, 09:04 PM   #101
Carondimonio is offline Carondimonio  Switzerland
Carondimonio's Avatar
Originally posted by PeterLeest
Hi Bruno,
I received the boards, very nice, thank you.
In post #65 attached circult, VR101 is 50K, however, I found in another link, the VR is 200 ohm. it could be to typo error.
http://www.kk-pcb.com/alephx.html
For the rectifier board, what is the value of R & C (example C1 & R1) ? Also, do you intend to use MUR30 (MUR3020WT) or MUR1560 for the Aleph-x ?
regards.
Hi all,
it's true, the value of VR101 is wrong, as it has been pointed out also in This Thread
Here's a copy of my answer to that:
"Hi all,
that is the schematic I posted on the Aleph-X PCB group buy thread.
It is directly taken from KK's Site and I've just redrawn it to create the PCB.
Now, the value of VR101 is wrong (my BIG mistake! ), it really must be 200 Ohms, as Grey pointed out. I apologise for this mistake.
As for R103, the value of 360 Ohms is exactly the same as on the original schematic I mentioned above. I do not know if it makes too much of a difference with Grey's original value of 330 Ohms.
With VR101 set to 0, the equivalent value of the parallel of R103 and R104 is 203.85 Ohms with R103=360 and 193.875 with R103=330 Ohms.
With VR101 set to 200 Ohms, the equivalent total resistance is respectively 255.53 and 249.1 Ohms.
I leave to the experts (I'm not one) to judge whether it's preferrable to set R103 to 330 Ohms or to leave it as it is. As far as I know, several Aleph-X have been already built following this schematic and they work..."
Here's the corrected schematic.
Bruno
Old 6th February 2006, 09:43 PM   #102
Default BOM for Main Board
Here's the BOM for the main board:
Old 6th February 2006, 09:54 PM   #103
regards.
Hi all,
the exact values of R & C on the rectifier boards depend on the diodes used, as well as on the transformer. A commonly used starting point is R=100 Ohm, C=100 nF.
Jim Hagerman (Hagtech) wrote a nice tutorial about "snubbers": Snubbers
As for the diodes, it depends on how much power you want to squeeze from your amp. For a low output power (20-30 W), MUR1560 will be enough, otherwise better use MUR3020WT or equivalent.
Bruno
Old 6th February 2006, 10:16 PM   #104
Hi all again,
today I ordered a new run of corrected rect. boards. They should be at my place in approx. 3 weeks.
Bruno
Old 7th February 2006, 05:04 PM   #105
lscangus is offline lscangus  United Kingdom
Originally posted by Carondimonio
Hi all again,
Bruno
Thx very much!, i have got my boards already, they are fantastic!, but i have a question, what is the value of the resitor on the FETS board.
Old 7th February 2006, 08:46 PM   #106
Hi lscangus,
the source resistors are calculated as follows:
R=0.5V/Bias current in each FET.
This is a nice tutorial.
And this spreadsheet will help you calculate all the important parameters of your Aleph-X.
Bruno
P.S.: Lately I've been very busy with professional and private matters, and I had to put aside my hobbies (including this one) a little bit. Please bear with me, I will try to answer all your questions as soon as I can, but please, do not get upset if I happen to disappear for a day or two every now and then...
Old 8th February 2006, 05:18 PM   #107
Jpnitrof is offline Jpnitrof  Canada
Default Late arriver ...
Hi carondimonio
I might be late but if I would be interested in a set of PCB's to build a stereo amp.
Old 9th February 2006, 07:09 AM   #108
Hi lscangus,
Bruno
What do you mean by 0.5V/bias current?
Angus
Old 10th February 2006, 03:14 AM   #109
eapavant is offline eapavant  United States
it means the r value = .5 divided by the bias current at each fet. also look here
http://www.diyaudio.com/wiki/index.php?page=Aleph-X
All the information you need should be linked to here.
-eric
Old 11th February 2006, 08:53 AM   #110
Jpnitrof,
did you get my mail?
Aleph-X Compact PCB Group BuyHide this!Advertise here!
Aleph J-X Amp Project Melon Head Pass Labs 1413 5th March 2018 07:13 PM
My Aleph-X compact PCB Carondimonio Pass Labs 154 28th January 2011 07:42 PM
WTB: aleph-x compact PCB ashaw Swap Meet 0 23rd March 2008 08:24 AM
Compact Aleph 5 module OliverD Pass Labs 22 19th March 2004 09:12 AM
