Soft switch version 2 anyone? - Page 7 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 2nd December 2005, 04:29 AM   #61
rjkdivin's Avatar
Default Soft Switch and Soft Start
Robert,
My second batch of kits arrived today in great shape.....thank you!
Robert
Old 2nd December 2005, 05:11 AM   #62
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
All my boards are finished and operational. Rob thank you for your help. After I reversed D1 I descovered that on one board I shorted small capacitor. Fixed that and v'ola everything was fine. All four boards ready to go.
AR2
Old 17th March 2006, 07:34 AM   #63
rjkdivin's Avatar
Default Soft Switch with Soft Start
Hi Rob,
I got all 4 of my soft switch and soft start boards finished. The soft switch boards are all working perfectly. I wanted to check with you to be sure that the soft starts are also working properly though.
They all do exactly the same thing when testing under no load conditions (just using a DMM to measure output voltage):
As soon as I turn on the soft switch, the soft start output jumps rapidly to full voltage before the relay trips. The pot adjustment for the delay works.....the delay of the relay is adjustable. But there is no change in the output voltage when the relay trips since it is already up to full input voltage.
Does this sound like they are working properly? Since the purpose is to limit current rather than voltage, my measurements may not mean anything?
Thanks! These are nice little switches.
Robert
Old 17th March 2006, 01:06 PM   #64
Send a message via ICQ to Maxhawk Send a message via AIM to Maxhawk Send a message via MSN to Maxhawk
Default Re: Soft Switch with Soft Start
Robert, this is a normal measurement. It as a voltage divider with 25 ohms in series, and 10 Meg shunt resistor (typical Rin of DMM). Vout=Vin*[10M/(25+10M)] => Vout=Vin.
The way to tell that the soft start is working properly is to listen for the delay of the latching relay.
--Rob
Robert Cheng
Old 17th March 2006, 04:27 PM   #65
rjkdivin's Avatar
Default Re: Re: Soft Switch with Soft Start
--Rob
Thanks Rob.....everything seems to be working properly on all four sets.
Robert
Old 12th April 2006, 05:46 AM   #66
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Does any one have pictures of the bottom of there board ? I need to see one.
Old 12th April 2006, 06:01 AM   #67
With or without components stuffed? If you need it with, I can get you one when I return back to the States after 4/19. Or maybe someone can take one for you.
Robert Cheng
Old 12th April 2006, 06:06 AM   #68
Banned
I hope you can or Some one can because i'm having a hard time building this thing with lack of instructions and parts id.
Old 12th April 2006, 06:12 AM   #69
Did I not include schematics, layouts, bill of materials, and assembly drawings in the package? If you don't have them, I apologize for forgetting them. You can find them on my site:
http://www.robcheng.com
Click on Audio -> Electronics -> Soft Switch V2
Robert Cheng
Old 12th April 2006, 06:26 AM   #70
Banned
You sent me a bill of material's but it does not show what part is witch.
example resistor 1003 means what ? or 1001
Also on the corner of the pcb it says r8 510 and looking at r8 on the x-cell sheet i see
R7, R8 Resistor 1K 5% SMD 1206 Panasonic
So im a little confused if i could see the bottom of some ones that works Id be happy.. Im going to stop tonight. So far i have a few 22k resistors mounted.and the 7812 and the bridge rectifier.
On another note i see this on the x-cell sheet
R1, R2, R6, R9, R10, R12 Resistor 22K 5% SMD 1206 Panasonic ERJ-8GEYJ223V
but on the board r6 says 1k. Soo.....
To debounce a soft switch kmj Solid State 8 22nd February 2008 09:02 PM
Soft start + switch on PCB smithy666 Solid State 29 4th September 2007 06:33 AM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 04:32 PM
FS: Kit for amp power soft switch Maxhawk Swap Meet 152 27th April 2005 07:22 PM
Copyright 1999-2017 diyAudio
