Mauro Penasa's INV GC/REF GC group buy. - Page 10 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 30th June 2005, 03:15 PM   #91
Mark Kravchenko
mwmkravchenko's Avatar
Default Good on one side bad on the other
The TF package is much more limited in it's ability to dissiapte heat. As such it can't be pushed as hard as the T package. There are good junction temperature curves in the data sheet.
MArk
Mark
www.kravchenko-audio.com
Old 30th June 2005, 03:20 PM   #92
Russ White's Avatar
Send a message via Yahoo to Russ White
When you add a good insulator/isolator (which you will almost always need) to the T package's heat dissipation is comparable to if not worse than the TF package. But if you really want it, maybe Brian will accomodate you.
Less pulp more juice Twisted Pear Audio.
Old 30th June 2005, 03:41 PM   #93
Mark Kravchenko
Default Point Taken
You are correct Russ.
THere are differences in the curves to suggest that the full pack version does warm up faster and cool off slower even with an almost the same thermal transfer number. The note to read is the derating factor if I remember right.
THere is only going to be some difficulty if the heatsink is on the small side and the amp is driven hard with a power supply voltage nering the max. Keep to around 30 volts after rectification or after the regulator and you will be just fine.
MArk
Mark
Old 30th June 2005, 05:21 PM   #94
BrianDonegan's Avatar
I think the schematic for this version of the amp specified 24VAC, which results in 33.6VDC for the rails.
Speaking of heatsinks, would anyone be interested in including them in the kit? Here's what I was thinking:
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Have him cut 3" pieces. One piece for each amp (3 x 5 3/8 inches). 3" would be $4.38 each, plus shipping charges out course. Could go to 4" for $5.84 each.
Old 30th June 2005, 05:25 PM   #95
Russ White's Avatar
That sound like a great idea! If 4" can dissipate enough heat I would be in for that.
Old 30th June 2005, 07:56 PM   #96
Gmorris is offline Gmorris  United States
Would anyone be interested in these heatsinks?
I'll most likely be using the sinks on the left (cut to size) for this project. I have some extras I'm trying to get $15/pair for....or maybe trade towards the kit?
Old 30th June 2005, 09:04 PM   #97
earsandeyes's Avatar
Default 3" or 4"
I am in for either 3" or 4".
Probably 3" will do.
E&E
Old 1st July 2005, 01:40 AM   #98
Anyone else want to offer an opinion of heatsink size/have interest in them? I can add it to the Wiki and consider it seperate from the main kit.
Old 1st July 2005, 01:48 AM   #99
Wiki updated with heatsink information and added to the grid. Just testing interest for now.
Old 1st July 2005, 09:46 AM   #100
Any informations:
I have found any numerations not correct on the BOM and have corrected it ( only the serigraphy references, the quantities are correct ).I attach the corrected version to verify. I Creed that you did a good work, Brian.
LM3886 T now TF: The T version ( not iso ) has theoretically a better ability of dissipate of the heat ( internal ) toward the heatsink. In my LM3886 circuit it has to dissipate " theoretically " a lot of energy if the load is 4 ohms. This calculations however I am in " sinusoidal continues power" that doesn't exist in the ordinary music. I have done my test with the "T" type (not iso), but I believe that for an "moderate" use goes well the TF type ( iso ) for the reasons lists from Russ...
Heatsink: I Suggestion to use a type with 1-1.2 C/W of Thermal Resistance, with vertical development ( like NS- AN1192 by BR100 mod. )
Ciao
Mauro
my_ref revC group buy (Mauro Penasa LM3886 design) schro20 Group Buys 650 17th October 2010 11:42 PM
Evolution Amplifier by Mauro Penasa Panelhead Chip Amps 14 22nd July 2010 09:56 AM
WTB: Mauro Penasa Ref C marginwalker Swap Meet 0 13th October 2007 05:28 PM
My Version of Mauro Penasa's LM3886 Stanley Drake Chip Amps 28 31st December 2006 12:41 AM
cant make it work: mauro penasa rev 1 zafira1981 Chip Amps 14 24th December 2005 02:33 AM
Copyright 1999-2017 diyAudio
