Group Buys Members group buys
Mauro Penasa's INV GC/REF GC group buy.
Old 1st August 2005, 07:33 PM   #271
Russ White is offline Russ White  United States
Russ White's Avatar
Originally posted by BrianDonegan
So, I was just perusing the 3W replacements for R1, R4, R24 and R27 to see what's out there, and noticed this note in the datasheet for the Vishay/BC resistors (currently 1W).
http://www.vishay.com/docs/28729/pr010203.pdf
The resistors should be mounted 8mm above the board (+/-2mm). Mine are about 2-3 mm. They get warm to hot, but no problems so far. Just a tip for those who haven't soldered yet.
I think the 3W version would do well as a replacement, though they cost 4 times as much. The 2W verision is only twice as much.
Did you look at the IRC thick films? I can't remember how much I paid.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 1st August 2005, 07:46 PM   #272
Russ White's Avatar
Also look for Sprague "BlueJacket" 2W wirewound type. I tried those, and they work great.
Audio
Old 2nd August 2005, 01:43 PM   #273
awashi is offline awashi  Japan
awashi's Avatar
Would a heatsink with 200 X 40 X 75 MM --- 0,7 °C/W be enough for cooling the amp?
Old 2nd August 2005, 01:53 PM   #274
Russ White's Avatar
Originally posted by mauropenasa
Any informations:
I have found any numerations not correct on the BOM and have corrected it ( only the serigraphy references, the quantities are correct ).I attach the corrected version to verify. I Creed that you did a good work, Brian.
LM3886 T now TF: The T version ( not iso ) has theoretically a better ability of dissipate of the heat ( internal ) toward the heatsink. In my LM3886 circuit it has to dissipate " theoretically " a lot of energy if the load is 4 ohms. This calculations however I am in " sinusoidal continues power" that doesn't exist in the ordinary music. I have done my test with the "T" type (not iso), but I believe that for an "moderate" use goes well the TF type ( iso ) for the reasons lists from Russ...
Heatsink: I Suggestion to use a type with 1-1.2 °C/W of Thermal Resistance, with vertical development ( like NS- AN1192 by BR100 mod. )
Ciao
Mauro
So anything with less than 1.2 deg C/W thermal resistance should be OK.
Audio
Old 27th March 2006, 08:57 AM   #275
Tergofante is offline Tergofante  Spain
Because i don't speak Englis, i wrote in Spanish:
Aqui añado mi contribución, pequeña.
He modificado la alimentación para disminuir el rizado y aumentar la Irms del los condensadores de filtro de alimentación, por trabajar a 100Hz.
Añado el esquema y la PCB
Old 27th March 2006, 08:57 AM   #276
And the PCB is here
Old 27th March 2006, 08:57 AM   #277
The TopSilk
Old 27th March 2006, 08:57 AM   #278
And last, but not the Last: The Bill Off Materials ( the BOM)
Mauro Penasa's INV GC/REF GC group buy.Hide this!Advertise here!
my_ref revC group buy (Mauro Penasa LM3886 design) schro20 Group Buys 650 17th October 2010 11:42 PM
Evolution Amplifier by Mauro Penasa Panelhead Chip Amps 14 22nd July 2010 09:56 AM
WTB: Mauro Penasa Ref C marginwalker Swap Meet 0 13th October 2007 05:28 PM
My Version of Mauro Penasa's LM3886 Stanley Drake Chip Amps 28 31st December 2006 12:41 AM
cant make it work: mauro penasa rev 1 zafira1981 Chip Amps 14 24th December 2005 02:33 AM
