Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 27th May 2005, 12:34 AM   #1
gengis is offline gengis  United States
gengis's Avatar
Default 65 + 65VAC 1kVA Toroidal Transformer
Anyone interest in getting some Avel Lindberg 1kVA toroidal transformers:
115+115V primary----65 + 65Vac secondary.
I have a quote for four transformers at $127 each. Price will drop if quantity increase.
I plan to use that on Mr. Holton's AV800.
price does not include shipping.
Old 27th May 2005, 02:40 AM   #2
K-amps is offline K-amps  United States
K-amps's Avatar
My 2 are are included in te 4 right.
Old 27th May 2005, 02:43 AM   #3
gengis's Avatar
K-amps,
That's correct.
Old 28th May 2005, 08:25 AM   #4
I just bought a cheap PA amp (Cmark) that runs +-95Vdc on the rails.
The transformer is 4*64Vac and other low current tappings for low level control etc.
But it is about 1.5kVA or possibly bigger.
Judging by the spec sheet the transformer limits 4ohm power output to 525w + 525w driving both channels together or 350w + 350w into 8ohm together. Yes 4ohm power is 1.2db down from 8ohm and a well specified PSU should only be 0.5db to 1db down at 4ohm.
If you also want to drive a difficult 4ohm speaker you should be looking at 2ohm spec and the ability to push enough current to produce about 1kw + 1kw together (-1.5db)
1kVA should be good for a monoblock at the voltages you seem to be aiming for or 2kVA for a stereo amp.
regards Andrew T.
Old 28th May 2005, 01:21 PM   #5
K-amps's Avatar
I have gotten 370 watts at 8 ohms RMS (just before clipping, ) from a single Avel 1kva 62-0-62 Toroid with +/-86 vdc rails. At 4 ohms I get 550 watts.
I doubt the tafo you have is 1.5kVA Andrew. With an Avel rated at 67-0-67, I am expecting about 500 watts 8 ohms at clipping.
Old 28th May 2005, 06:16 PM   #6
to me it looks too big to be 1kVA, 175mm diam by 72mm high and I think it is too small for the 4 ohm duty in stereo.
That's why I suggested that you look at something bigger or use as a monoblock.
regards Andrew T.
Old 14th June 2005, 01:25 AM   #7
gengis's Avatar
K-Amps,
I guess just you and me. When do you need these transformers?
Old 14th June 2005, 01:56 AM   #8
K-amps's Avatar
Sooner the better
Old 14th June 2005, 07:17 PM   #9
still4given's Avatar
Did you guys see these?
How do they compare with the ones you are buying?
Blessings, Terry
Old 14th June 2005, 10:39 PM   #10
gengis's Avatar
Blessings, Terry
Now I have, I had seen this person's advertising before.
In fact, the one I have received look just like that. But w/different secondaries.
Superlative Mono UcD400HG with 1kVA Toroidal gsattler Class D 16 20th January 2009 10:39 AM
FS: PLITRON 1KVA toroidal alexl Swap Meet 1 9th July 2005 05:25 PM
4 SALE! 1KVA Toroidal Transformers jleaman Swap Meet 5 16th May 2005 01:03 PM
WANTED: 1KVA Toroidal's led_zeppelin Swap Meet 5 12th December 2003 10:26 AM
New Plitron 1kVA Transformer roddyama Swap Meet 3 6th March 2003 10:46 PM
Page generated in 0.10073 seconds (79.47% PHP - 20.53% MySQL) with 10 queries
