Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 5th May 2005, 10:02 PM   #11
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Andrew,
1) ok, I will use a 3 pin input header, and use on as DC coubled input.
2) There is no need for a DC pot, I have not measured above 40mV DC on the output on any of the 8 channels I have build using 1% resistors and unmatched semiconductors.
About the PDF, I can make a better resulution (BIG files ), or I can post GIF pictures in stead of the PDFs
\Jens
Old 5th May 2005, 10:11 PM   #12
loek is offline loek  Netherlands
Default DC setting
Hi AndrewT.
I build the first Leach in '81 and one amp had a little offset, 73 mv.
To make this zero i added an (outboard)offsetcircuit like the KSA50.
Before building the second channell i paired the small signal transistors and when it was finished the offset was about 15 mv.
Perhaps Jens can give us his amps offset voltage?
Good luck, Loek
Jens is very fast, he answered before I could post....
Old 5th May 2005, 10:16 PM   #13
Just to make the thing complete, I will look into the DC setting,
Could someone point me to where I can find an examble of the circuit?
\Jens
Old 5th May 2005, 10:31 PM   #14
Hi Jens,
Pinkmouse posted http://www.diyaudio.com/forums/attac...amp=1115075661 (about post 1673?)just a couple of days ago (just my luck cos they're over 1700 posts now)
The components are VR1, R103-107, R131, D109, 110, C110, 111.
regards Andrew T.
Old 5th May 2005, 10:48 PM   #15
Default dc offset
Hi Jens, I dont 'think it is needed. But you can indeed use this circuit.
In the Krell it is connected to the feedbackside of the input circuit.
I made it more simple without R104 and R106 and placed it to the input side. R131 is 47k in my amp and I also placed a small cap from the wiper to ground.
Loek
Old 6th May 2005, 01:27 PM   #16
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
1 The added pads on the boards for raised front end voltage are very nice.
2 Would it be an idea, (and possible), to add Michael's triple soa protection to the board ?
3 with 10 components added for DC-zeroing you might as well make it an active offet regulation with an OP** opamp.
With the current layout i dont see the room for adding that many components. But i am not a pcb-designer.
Looks like Sponge Bob has killed another thread.
Old 6th May 2005, 01:56 PM   #17
pooge is offline pooge  United States
Jens,
Have you sought any comment from Prof. Leach re the boards and the layout? After almost 30 years of experience with this circuit, he may have some valuable input.
Old 6th May 2005, 02:15 PM   #18
On the Leach thread i suggested to ask BrianGt to approach Professor Leach for advice on the design.
Brian is a former student of Marshall Leach, and still resides in Georgia afaik.
Personally, i would be more than interested in what Professor Leach would suggest for the feedback values when using higher bandwidth devices. imo, this is/could be the V5 design.
Old 6th May 2005, 04:02 PM   #19
1) Well, you always wanted those anyways, so I figured what the heck.
2) I already made a dual slope soa protection awalible on the board by adding R68 and R69
3) I played arround with the DC circuit last night, but could not fit it without redoing the input section. Should I bother or just leave it the way it is?
\Jens
Old 6th May 2005, 04:33 PM   #20
speaking for myself:
i will be matching devices anyway, if needed i'll measure a number of resistors and pick the one that makes DC offset minimal, or pick a device that does that .
If the outcome doesnt please me i'll add an active offset regulation, with an amplifier as the Leach i have no problems with that.
The front part i like the way it is, is is closely nested, nice symmetrical, well separated from the current part by the big capacitor spacing.
Leave it !
Jens Rasmussen Leach clone group buy tryonziess Group Buys 1442 30th November 2011 12:28 PM
Page generated in 0.09810 seconds (88.20% PHP - 11.80% MySQL) with 10 queries
