| Group Buys Members group buys |
Hi Everyone,
I have found a heat sink distributor for Seifert extrusion number KL-271: ![]() With the fins oriented vertically, this heatsink measures 12" wide, 8" long, 3.25" thick, and has a 1/2" thick back plate. A singe 8" (200mm) length of this heat sink with black anodize and natural convection is rated for 0.18c/w or approximately 140-150 One of these would comfortably run a stereo Mini-Aleph. Two of these sinks would provide 0.09c/w of cooling that can dissipate approximately 280-300 watts and should be sufficient for a 100wpc Aleph-X monoblock or even an Aleph 2 monoblock. The distributor has a minimum order of 10 pieces, which is more than most people might want, so I have inquired about the possiblity of a group purchase and different quantities and price points. To give you an idea of cost, the unit price for 10 of these heatsinks is approx $60 each (not including shipping). I will be able to provide more details shortly... Any interest?? I will post more details shortly, and if there is sufficient interest, I'll set up a wiki... Eric |
#2 |
I'd probably be interested. Is that a good price, or are you hoping it will go down significantly with more units?
#3 |
I am interested in at least 2, could be up to 6 depending on price vs. quantity.
Who is the distributor? Does have a website? |
#4 |
I'd be interested in four pieces, if the price can be brought down with higher quantities.
I had purchased 12 pieces of extruded heatsinks from M&M Metals for about $300 shipped. The heatsinks were 8" in length, 6.695" tall with alternating 2.2" and 1.2" fins, with a base thickness of 0.2". Obviously the one you're suggesting is much larger, but I could buy four of the other heatsinks for the price of two of the larger ones. In case you want to look up the extrusion I used, it's MM11645 located here: http://www.mmmetals.com/pages/extrus...n_4_and_up.htm You'll need to scroll down just a little bit to find it. The thermal resistance they list (0.8C/W) is for a 3" length. |
#5 |
diyAudio Moderator Emeritus
Here is an amp that uses the 200mm version:
http://www.passdiy.com/gallery/alephx-p3.htm Ignoring the piles of large heatsinks in my basement, I would be interested if the price dropped. I am sure that if you checked different vendors, you could a similar extrusion for cheaper. I also like the MM heatsinks that Rob (maxhawk) used, and they have been used in by others for Aleph 2 amps: http://www.passdiy.com/gallery/aleph2-p1.htm http://www.passdiy.com/gallery/aleph2-p2.htm Rob's chassis: http://maxhawk.flagshiphosting.com/p...each/index.htm or http://www.briangt.com/gallery/leachamp-5channel Chassis I helped another friend make: http://www.briangt.com/gallery/jeetamp MMM might also have more beefy extrusions if you give them a call. -- Brian |
#6 |
IF the price drops , then I am interested in 2-4.
left lane is for passing, slower traffic keep right please. |
#7 |
Come to think of:
I would actually prefer the 400mm width one, One piece of heatsink per side (12" is little short for the chasis). |
#8 |
I'm currently using the 300mm lenght sink for my Mini-A. I'm running the fets at 2.4A/pc. The sinks settles at 65 degree C. I really think that you need more area to be able to dissipate for a 100W AX.
My 2 cents, Kari |
#9 |
IS it difficult to cut these into smaller lenghts, ie. reduce the 8" length to 3.5 to 4"? Can a table saw do this?
#10 | |
-- Brian |
| Heat sink group purchase for USA & Canada | Eric | Solid State | 0 | 4th May 2005 02:48 PM |
| Canadian Heat Sink Group Buy | Coulomb | Group Buys | 68 | 21st February 2005 08:31 PM |
| Europe and North America | serengetiplains | Everything Else | 17 | 15th August 2004 11:08 PM |
| Group Order: Satin Aluminum Knobs from India - Ordering Thread (North America) | PHilgeman | Chip Amps | 1 | 12th March 2004 01:11 PM |
| New heat sink group buy | Brian Donaldson | Pass Labs | 5 | 25th January 2003 10:13 AM |
| Page generated in 0.11031 seconds (78.30% PHP - 21.70% MySQL) with 11 queries |
