Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 1st April 2005, 07:50 PM   #21
kepa1 is offline kepa1  France
hello,
i may be interested in 1 MOXlite complete with PCB+parts... but only if there is enough documentation for a beginner like me!
i'm especially interested in the "no additional trafo needed" theory.
regards,
alain
Old 2nd April 2005, 06:19 PM   #22
I would like 8 Mox lite.
Q is the discrete opamp of benefit for all frequency ranges i.e. sub-bass, bass, mid & treble?
or
is most benefit for treble only? and maybe mid (800Hz to 6kHz).
regards Andrew T.
Old 2nd April 2005, 09:36 PM   #23
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
How much is a single board ?
Is on board per frequancy so if i have 3 way speakers i need 3 board's ? or am i missing something ?
Is that the compleet looking board ?
J'
Old 4th April 2005, 01:04 AM   #24
tiroth is offline tiroth  United States
Okay, these are the numbers so far:
MOXlite
Nisbeth: 4
Joster: 4
BG: 8
Jonk: 4
Kepa: 2
AndrewT: 8
Marius: 4
Total: 34
MOX v1.1
Illusus: 4
Joster: 4
Cambe: 4
Total: 12
Based on this interest, I don't think there are enough for a MOX 1.1 order at this time. I'll keep appraising the situation though.
I will definitely go ahead with a MOXlite order. The price is $8 for a single board. I do have a good number of opamp boards available.
jleaman,
The board includes input buffer, two bandpass sections, and a high pass section. It also includes two parametric EQs and regulators.
kepa1,
I will publish schematics and a spreadsheet for determining component values.
AndrewT,
Personally, I think the discrete opamp is most valuable in the mid+high; I don't think there is so much of a difference at lower frequencies.
Here is an updated PCB. I created a separate power ground run, increased the capacitor spacing (except for the 100pF input caps, all caps can be at least .280"/7mm wide), and cleaned up the ground plane some more. Please let me know any other comments.
Old 4th April 2005, 01:18 AM   #25
Banned
MOXlite
Nisbeth: 4
Joster: 4
BG: 8
Jonk: 4
Kepa: 2
AndrewT: 8
Marius: 4
Total: 34
MOX v1.1
Illusus: 4
Joster: 4
Cambe: 4
Total: 12
jleaman,
kepa1,
AndrewT,
You got Mail.!
Old 4th April 2005, 01:21 AM   #26
Here is a pic of a proto board. The MOXlite boards will have soldermask and silkscreen. I also flipped the ground plane on this protoboard for ease of soldering.
I'll post info tomorrow on how to officially sign up for the order.
Old 4th April 2005, 08:56 AM   #27
hello tiroth,
i'm glad the project is coming to life.
correct me if i'm wrong but my aim is to active filter a single sub woofer, so i only need 1 mox lite.
regards.
Old 4th April 2005, 09:21 AM   #28
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Tyler,
What kind of EQ section do you use?
Can you get Excel to draw gain and phase graphs for the filter?
Will you need input to a manual?
\Jens
Old 4th April 2005, 01:40 PM   #29
SvErD is offline SvErD  Norway
SvErD's Avatar
MOXlite
Nisbeth: 4
Joster: 4
BG: 8
Jonk: 4
Kepa: 2
AndrewT: 8
Marius: 4
Total: 34
MOX v1.1
Illusus: 4
Joster: 4
Cambe: 4
Total: 12
Seems like you missed my post? ah, I didn't put a number..............
I'd like 4 x MOX lite.
cheers
Svein
I don't suffer from insanity, I enjoy every minute of it!
Old 4th April 2005, 03:10 PM   #30
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Default Alternative to Cauer-elliptic filter
These boards are of interest to me for the option of bi-amping a combination of PE's RS-180 with the SEAS 27TDFC. This is done quite well with passive components by Jon Marsh and found here:
http://www.htguide.com/forum/showthread.php4?t=11321
My reservation for using his passive crossover is the cost... over $200/ speaker. I believe this board provides a cost effective alternative. The aluminum cone RS-180 has break-up modes that should be removed with a steep-sloped x-over, such as 48 dB/ octave.
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
PA vs DIY active crossover paulspencer Multi-Way 46 27th November 2004 01:25 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.12729 seconds (80.14% PHP - 19.86% MySQL) with 11 queries
