Group Buys Members group buys
New Ultrafast Diode Bridge group buy?
Old 6th October 2004, 10:29 AM   #1
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
Default New Ultrafast Diode Bridge group buy?
Well, after being fairly lazy about trying to sort this out I guess I have the time to try and sort through this now, so here it goes.
What I will be doing here is offering up a board very similar to that which was made last time round which will accommodate a set of ultra fast switching diodes (either dual TO-247 devices, or single TO-220) along with a snubbing network and space four heat sinks etc.
There will be some minimum order numbers which I will have to hit before this becomes worthwhile doing though, which would be 100 of the PCBís and at least 25 full setís of component kits (although again like last time I will try and supply the spade PCB connectors as Iím not sure how easy these will be for people to et hold of individually)
You can see a picture of the board in an assembled state at the end of this little lot of text, and I will include a description of the components which would be in the kit on the wiki page which I will go and set up now to try and gauge interest in doing this again, but if any people have any questions about things then feel free to post on here and I will try and answer them as quickly as possible (which also goes for the pricing which I will have to go off and work out for the component kits now, but which would probably remain at £4 per PCB as it was last time so long as the board house donítí charge me any more this time).
Andrew.
Old Component order page
Old PCB order page
Old 6th October 2004, 10:32 AM   #2
bigparsnip's Avatar
Just one more picture to give a clearer look at teh PCB and show the alternate method for cooling if you want to put a lot of current through the diodes.
EDIT:
Ok, here is the link to the new wiki page, it doesn't have much information on it yet, as most of that can be found in the old threads (or you could ask here) and I have to head out now so it may be added at a later date if this looks like it will take place again.
Andrew.
New Group order wiki page
Old 6th October 2004, 12:22 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I only want to remind you that your insulation distances are too small. I recommend that you increase them to 1 mm or more. Calculate for max voltage 200 volts at least.
You may also place the pads in zick-zack so you get more space. What don't you place the e TO220 devices a bit from the heatsink. It's easier to bend these TO220's compared to the TO247's.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 7th October 2004, 02:27 AM   #4
Strohmie is offline Strohmie  United States
I'm in for three kits and three boards.
Old 7th October 2004, 03:35 AM   #5
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
ill throw down for four of them. the aleph2's will need a good rectifier
Old 7th October 2004, 01:13 PM   #6
seve is offline seve
Thanks for starting up this thread
Before signing up in the wiki I would like to know if it's possible like the last time to get the kit without diodes and if so what the price will be?
Martin
Old 7th October 2004, 01:24 PM   #7
bigparsnip's Avatar
As long as there are sufficient order numbers to hit the price cuts that I need to place the orders I should have no problems with people taking the components they want for the boards. However, as I doub't this will be as large an order as last time if it does go through, it will probably work out a little more for some of the components, so you could expect I think a price of around £9.00 for a PCB and all of the componets apart from the diodes (although this could be a bit more if I can't get the parts from the same sources as last time)
Old 9th October 2004, 04:44 PM   #8
Clarkcr is offline Clarkcr  United States
Clarkcr's Avatar
Hey this is just what the doctor ordered... I've been looking for a high speed diode set for my Aleph 1.2s I'm building. I guess this is it???
Tell me....I'm using a 2000VA 50v dual primary toroid and 6 72,000uF caps to make a CRCpi type PSU with some resistors inbetween the first four 72KuF caps and the last two 72KuF caps. Is this the fastest switching setup I could get for my project?
What is the difference between this and a "hexfred" setup? I am told by a good friend of mine that I should use 8 hexfred high spped diodes in TO247 cases. I see from the picture that there are four per PCB.....if I'm using dual primaries, then could I benefit from using one of these boards (4 diodes) per primary out from my trannie? In other words two PCB setups per chassis?
Sounds good. Someone school me and I'll be in.
Chris
Old 9th October 2004, 05:56 PM   #9
bigparsnip's Avatar
Hi, as this is a fairly generic PCB allowing you to use any suitable connected single TO-220 or double TO-247 diode type package you should be able to find a device which will do what you want it to for your amp (the diodes that were in the kits last time were the ones that are used int he PASS labs amplifiers so they should be a good starting point for you to look at).
Also, the way the PCB is configured, it is equaly possible to use one or two of them for a single supply (so long as you have dual secondaries on your transformer which it looks like you have) depending on what you fancy putting into your amp.
Anyway, hope this has answerd your questions, but if it's not specific enough, just let me know and I'll try to clarify things a bit more.
Andrew.
Old 9th October 2004, 06:11 PM   #10
wytco0 is offline wytco0  United Kingdom
OK silly newbie question time again!
Why can't centre tapped transformers be used with this board?
New Ultrafast Diode Bridge group buy?Hide this!Advertise here!
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
IR HFA08TB60 Ultrafast Soft-recovery DIODE canvas Swap Meet 1 21st August 2004 04:47 PM
Ultrafast Diode bridge substitution fr0st Parts 10 16th February 2003 04:00 PM
Copyright ©1999-2017 diyAudio
