Group order of non-inverted LM4780 pc boards? Anyone interested? - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 11th May 2004, 02:49 PM   #21
Originally posted by Peter Daniel
I would be much more concerned with via than a T. There is no problem running this trace directly between pads, without the need for a T. I wouldn't recommend mixing 2 layers for that.
This is a NFB system. The output should be taken from the same point that the FB is sampled from. That point is R1. The current flowing in the T shaped track will cause voltage variations, which equals distortion. The currents will be measured in amps, and the distortion will be easily measured, and perhaps audible. This in itself might not be a big deal, but when it's easy to fix, why not?
The via will not cause problems because it means the output will be taken from R1. Sure, it might add some resistance, but this will be swamped by just the tolerance of R8.
As to the output ground 200mill won't make a difference in performance, but it will make big difference in how easy it is to run the connection wire. I don't care for perfect symetry. I care much more for convenience.
Sorry - I don't see how moving OG will alter this. I proposed moving it to between SQ and OUT - that it, move it south, then east a bit so that it's directly above the OP pad. This will make wiring simpler because you can group (or twist) the OP wires. It means altering the blue output trace slightly, but that's all. Again, it's easy to do, and will have a positive effect on the performance. Why not?
The spacing it's done here on purpose. Those are not Krell boards where everything is lined up and spaced perfectly. The board accomodates Caddocks, but I have strong feeling that Rikens will be better here, so this extra space allows to mount Rikens as well (in vertcal position). You wouldn't mind putting them this way? After all those extras on the leads are part of 3-D layout, (popularasied by Jonathan Carr)
Sorry - you can't convince me that the uneven spacing was deliberate. This is just how things look after the first "pass" at placing components without using a horizontal grid. If it was deliberate, why is R4 so very close to R8, causing the blue SG trace to almost touch the output node. BTW, this is bad, because the current in the output node could easily induce currents in the SQ, causing yet more distortion (although this partly depends what the IC does with it's GND pins, and I can't comment because I've yet to see an internal schematic).
I wouldn't like to mount resistors vertically - this is universally bad practice on a PCB. What JCarr is quite different - he uses this technique to shorten signal path lengths. I was planning to use 1/8 watt resistors that mount horizontally, bit would consider using those square-body resistors that I've seen (sorry - I'm not up with the brand names)
Even if you place those resistors closer to the chip, you still have to run the connection wires around the board (this makes those wires longer) so I don't see much difference here. And anyway, there is no space to place those resistors there. Again having conveniently placed input access points on the board was major deciding point.
If you moved the resistors nearer the IC, the traces between resistor and IC gets shorter. The trace from I/P pad (which doesn't move) becomes one of the two traces that you currently have. You might have mis-understood the point - in terms of suscecpability to RF pickup, the traces between IC and resistors are more sensative because they are at a higher impedance, so these should be "protected" or shortened. The trace from IP pad is at a lower impedance, so is less of a problem. Lookup guard-traces in any precision op-amp datasheet.
Regarding the "trace from R6 looks very close to the R9", look how close those are on IC pins
You're missing the point - sure the pins are close together on the IC, but look at how National allocated them - the OP pins are seperated from the IP pins by power lines. Indeed, this is normal practice in most amplifier ICs. Again, how much effort would it take to move that trace south a bit? If there's even the slightest doubt about something, and it's easy to fix, then why not?
It took at least 5 days and countless hand drawings to finalize that layout.
I'm still working on a DAC (for almost a month) before committing to final layout.
So be asured that a lot of thought went into those amp boards. Also, we ride on experience gained with a previous version, which tested by hundreds brought only positive feedback
I'm not suggesting that you've not spent a lot of time on this. However, I took quite a lot of time to reply to you, and suggested some genuinely simple things that you missed. I could have suggested lots of other things, but realised that you don't want to re-design the whole PCB at this stage. I thought I was being helpful - the suggestions were based on my experience and understanding of the theory - which is just as valid as your original input, even though you don't seem to think so.
Sorry if that's harsh, but despite the use of smileys, the tone of your replies is dissmisive. In the time it took you to start replying, I can't believe that you even had time to read the message properly, let alone think carefully about a response - you must read very quickly
As I keep saying, if there's even the slightest doubt about something, and it's easy to fix, then why not? It's this attention to detail that makes a product unique and rewarding.
YMMV
Best regards,
Mark
PS What does BrianGT think?
Old 11th May 2004, 03:21 PM   #22
garbage is offline garbage  Singapore
garbage's Avatar
Default 4 ohm speakers ok for bridged mode?
any ideas if it would be ok to use a 4ohm speaker for bridged mode?
i understand that each amp(when bridged) will see the speaker as a 2ohm load per channel, but want to know if the lm4780 can take such a load.
Old 11th May 2004, 03:29 PM   #23
Looks like another good design!!!
It's better to have loved & lost than to never have had a good pair of speakers at all.......
Old 11th May 2004, 03:44 PM   #24
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Mark,
Thanks for the your comments on the layout. I spoke with Peter, and I will make some revisions to the design and post a new screen shot this evening. I find your concerns to be valid, and I will see what I can do.
Brian
Old 11th May 2004, 03:44 PM   #25
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Via is not an option in a well designed, audio board, sorry.
Besides replying on a fast, I aslo took your suggestions seriously, and will try to implement, togethe rwith Brian, to the best degree. But some things are either negligable, or simply not possible.
You mught not like vertical standing resistors from aestchetical point, but if they sound better, I will not loose sleep over that. Those resistors are vertical in order to maximise the width of ground plane. You can always use smaller size regular ones , or Caddocks.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th May 2004, 03:48 PM   #26
BrianGT's Avatar
Default Re: 4 ohm speakers ok for bridged mode?
The amplifier board uses 2 channels in parallel with the LM4780, so each channel would see 8 ohms on the amplifier pcb if you are just using one pcb. When you bridge two amplifier boards, each amplifier board will see half of the load, but since there are 2 channels in parallel on each board, each channel (4 of them used in a bridged setup), will see a 4 ohm load.
Brian
Old 11th May 2004, 03:49 PM   #27
lgreen is offline lgreen  United States
lgreen's Avatar
Default red boards
I'm interested in sufficient boards for 4 or maybe 5 bridge parallel channels. Red boards preferred. What will 4 ch of bridge parallel need? About 8 boards? Probably don't need all those power supply boards for this application.
Old 11th May 2004, 03:59 PM   #28
I didn't miss anything, Brian did the final layout, following my earlier suggestions. If I modified it, it might have look differently, as well. My points are valid, regarding major design decisions, not small details.
www.audiosector.com
Old 11th May 2004, 04:14 PM   #29
The spacing between those resistor should be according to that scetch. Only than installing Rikens present's no problem. This spacing is deliberate. It seems like Brian didn't do it quite accurately though.
www.audiosector.com
Old 11th May 2004, 04:27 PM   #30
Originally posted by BrianGT
Mark,
Brian
Thanks for offering to consider my suggestions, Brian. That's all I ask
Genuine question - Can I ask why?
I only wanted you to consider them as possible options. Can you at least understand why the speed and tone of the reply didn't suggest this?
My concerns for this are not aesthetic - I was thinking about the (real) possibility for RF pickup again. I've worked in different dissiplines over the years, and I guess that certain experience makes you worry about certain things...
So, have you found that mounting resistors vertically improves the SQ? Or, are you thinking of comparing different sorts? For example, I quite like 0.1% RN55's, which would have to be mounted vertically on this PCB - if I compared these to standard quality miniature 1/8W resistors (mounted horizontally), would the audible differences be due to the component or mounting method?
Best regards,
Mark
Copyright ©1999-2017 diyAudio
