Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 20th September 2004, 03:48 PM   #211
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Here's the trace width increased to 120 mil. It is fine like that.
I also tried 140mil, but didn't feel comfortable with that width, if not only for difficulties with soldering.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 20th September 2004, 03:55 PM   #212
fireman is offline fireman  Canada
fireman's Avatar
Having read this thread since the beginning, I must say I am quite interested in it. One question that has not really been addressed is the VA rating of the transformers that will be used to power these amps. In post # 56 mhennessy came to the concluson that 25 to 28 volt secondaries would be required to power them. Unfortunately, I don't recall reading anything about the VA rating.
I know that Steve of Apex Jr has some 28.4 V at 150 VA Avel-Lindberg toroids so I was wondering if these would work in a dual monoblock configuration. I quite sure they would be under powered for the bridge configuration but would they be OK for the single board configuration ?
Old 20th September 2004, 04:14 PM   #213
Those transformers would probably work fine with the boards, but again, higher wattage may be even better.
www.audiosector.com
Old 20th September 2004, 04:27 PM   #214
troystg is offline troystg  United States
troystg's Avatar
Everything in my GC is shielded and the amp is DEAD QUIET as a result. I would hate to but the diodes close to the audio circuitry and have noise induced there when the shielding could help prevent that.
Thanks again, and anxiously waiting,
Troy
Old 21st September 2004, 08:57 PM   #215
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Well, I spent some time looking over the LM4780 files, and will get some boards made soon.
Here is a picture of the board, showing both layers and silkscreen:
and a picture of the bottom layer of the pcb:
The pcb is very similar to the size of the LM3875 board, but the amplifier board is a bit bigger. The overall dimensions of the pcb is 2.9" wide by 5.2" deep, compared to the LM3875 board being 4.8" deep.
Any comments on the layout? The recent modifications that Peter and I made are:
- move input wiring a bit farther from the output, and add ground trace in between
- remove ground plane from rectifier board and restructure a bit
- slight modifications to placement of zobel components.
- increased size of SMD pads for mute resistor to allow a through-hole resistor to easily be soldered in this place.
I am looking to get the boards made soon, after I look over the layout a few more times. I am considering doing a small prototyping run first for testing first.
Brian
Old 21st September 2004, 09:13 PM   #216
troystg's Avatar
Hey BrianGT-
You said:
"- remove ground plane from rectifier board and restructure a bit"
Why did you remove the ground plane? Does it cause a problem that I am unaware of?
Thanks,
Troy
Old 21st September 2004, 09:25 PM   #217
BrianGT's Avatar
Originally posted by rabstg
Hey BrianGT-
I didn't think that it would be very useful in the way that it was setup, and might possibly pickup more noise then prevent. The recent one that Peter created wasn't tied to anything, and would be tied to ground on the chassis side. I decided that I would rather have the design of the rectifier board to mirror the current LM3875 board, since it seems to work rather well. Notice that I intentionally didn't put wiring for two boards from one power supply board, since the LM4780 will draw more power (should be same as 2xLM3875 boards). The dual-mono configuration will be standard with the kit.
As for a bridging board to go with the kit, I haven't had time to do any prototypes, so I decided to leave it out of the kit. Maybe after a few DRV134 boards have been prototyped, I will add a board for it to the pcb set.
Brian
Old 22nd September 2004, 12:20 AM   #218
Variac is online now Variac  United States
diyAudio Editor
Variac's Avatar
I thought that there was going to be room for diode heatsinks and a logical layout to make it easy to attach a htsnk plate between the rows of diodes so people could use them if desired, or use the rectifier boards for other projects.
Old 22nd September 2004, 03:40 AM   #219
I did one layout with diodes facing back to back and one heatsink plate, but then we discussed with Brian the possibility (and danger) of rectifiers touching each other (when not aligned properly) and creating hazardous situation, especially when the boards are to be used by so many people.
There is still enough room to use two heatsink plates, shared by 4 diodes.
www.audiosector.com
Old 23rd September 2004, 03:45 AM   #220
rnoble is offline rnoble  Australia
I hope this is the right place for advice on GC kit ideas
I am considering a 3 channel GC project. I have just ordered the parts and am now planning the layout. However in this planning my ohms law is a little rusty these days, particularly with “VA” ratings which I took to mean Volts*Amps which confuses me on Power which is V*I which is also volts by amps! Anyway I have some questions below and would really appreciate some experienced DIY Amp builder’s input.
I have attached an image with the topology of the setup.
- Can a 300VA tranny successfully run 3 gc amps?
- Is a 300mm long by about 70mm high finned heatsink enough to keep them cool?
- Will the tranny draw more than recommended 3A slow blow fuse?
Using a larger transformer, possibly 400VA is an option but costs will rise (including case requirements). The datasheet for the LM3875 would suggest that 34v post rectified is ok for running 6ohm speakers but was wondering what others experiences were on this.
A picture of the case with its heat sinks (an AKSA kit is being used) is on the link below. Transformer will be the same as seen (if feasible) but naturally the rest will be different, using GC kits from BrianGT. Case example
Page generated in 0.12884 seconds (78.83% PHP - 21.17% MySQL) with 11 queries
