Group Buys Members group buys
GB: Round #3; Fo-Felix & GB #1 AC Receptacle Enclosure
Old 8th August 2018, 06:30 PM   #51
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by Destroyer OS View Post
Then when you put Teflon capacitors in conditioners they sound different than PP counter parts.
It would be very strange if they sounded the same.
By different you mean worse?
I have an incomplete impression of teflon caps, based on only two makes, none of which were the universally praised Venhaus caps. For this reason i find it hard to generalise... perhaps some of them do sound good.
Old 8th August 2018, 07:59 PM   #52
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
That's a hard distinction to make. Usually if something sounds different and someone assumes it could be better, they just go with the assumption that it is indeed better. If they later remove said things or switch they may find their true preference. At least you see this all day in the audiophile world.
In a power conditioner the cap is attenuating noise from line to neutral. The properties of telfon vs PP in this application are not much different. The basic capacitance will dominate the situation. Where they differ is in 3HD distortion, and Teflon's SRF may be low enough to act like a short for some high frequencies. The odds that the Teflon isn't contributing 3HD and or exciting some frequencies by actings like short, are pretty remote if it sounds obviously audibly different. Why? Because unless you're comparing 10uf teflons to 0.01uf PPs then there just isn't a reason to account for the difference otherwise.
Old 9th August 2018, 08:54 AM   #53
analog_sa's Avatar
This is the only point where we disagree. Care to put numbers on the "3HD" level?
Which is the signal that gets distorted? What are its parameters? It is obviously proportional to the load modulating the current draw, but what kind of amplitude do you expect when an amp is running at close to maximum power? What about at a really low power? Or if the load is not an amp but a source, as these caps are equally audible supplying power to sources? What if the load is a constant current draw amp - would you expect the caps to suddenly become transparent?
Once you put the numbers you will realise that the amplitude of the signal which may get distorted is tiny, the distortion products of the caps at best are -140db below this tiny amplitude and they get further reduced by all the downstream PS filtering and by the device psrr. So, how much water can this theory hold?
Old 9th August 2018, 04:18 PM   #54
It's not a theory that they sound different. Many reviewers and customers have posted about it. They aren't series, or in the path of the signal, so I don't follow your "transparent" comment.
The frequencies that are affected are highly parasitic and don't play by the rules that 50/60hz does.
Old 12th August 2018, 04:01 PM   #55
drkingweeb is offline drkingweeb  United States
Default cases
will there be a gb for enclosures?
thanks,
drmike
Old 12th August 2018, 05:25 PM   #56
There is one going on already...
Right now I have ordered one that I can assemble and show off. It's taking awhile for him to get to it. If I don't hear from the guy doing the CNC I'll bug him after another week or so. I'm hoping that will when people see it, that'll be the convincing point.
GB: Round #3; Fo-Felix & GB #1 AC Receptacle EnclosureHide this!Advertise here!
GB: Round #2; Fo-Felix EMI Filter for AC mains 120/230v; By Folsom Destroyer OS Group Buys 94 12th August 2018 11:50 PM
How to achieve a smooth finish on a round enclosure? Blueroom Construction Tips 15 10th August 2013 06:48 PM
half round speaker enclosure exipnos Multi-Way 3 7th February 2012 09:38 PM
WTB: AC Power socket (IEC receptacle) vrao81 Swap Meet 3 30th September 2008 10:26 PM
Cleaning Toslink Receptacle fmak Digital Source 4 24th January 2006 12:04 PM
