Group Buys Members group buys
LTC3784 2/4-Phase Boost Converter for up to 55V Output 600/1200W (TPA3251, TPA3255)
Old 3rd July 2018, 11:03 AM   #1
doctormord is offline doctormord  Germany
doctormord's Avatar
Default LTC3784 2/4-Phase Boost Converter for up to 55V Output 600/1200W (TPA3251, TPA3255)
Anyone in for a testrun of a LTC3784 2/4 phase boost converter?
LTC3784 2/4-Phase Boost Converter for up to 55V Output 600/1200W (TPA3251, TPA3255)-polyphaseboost-1-jpg
The converter ist meant to power a class-d amplifier from different sources and is intended for use with the TPA3151 or TPA3255 but not restricted to this.
LTC3784 2/4-Phase Boost Converter for up to 55V Output 600/1200W (TPA3251, TPA3255)-59_ltc3787_schematic-png
LTC3784 2/4-Phase Boost Converter for up to 55V Output 600/1200W (TPA3251, TPA3255)-169_compensation-png
Design is made for either 2 or 4 phase operation at ~250kHz.
Input Voltage is 10V minimum up to the desired output voltage with pass through if the input voltage is higher than the output. This is especially usefull when using a 10s lithium pack to power an amp at 36V native voltage. As long as the pack voltage is higher than 36V (42V max for 10 cells) it is passed through the converter for best efficiency. When the input drops below 36V the converter starts boosting. Efficiency is in the range 90-98%.
Simulations are done for 1000W cont. load:
2 phase:
LTC3784 2/4-Phase Boost Converter for up to 55V Output 600/1200W (TPA3251, TPA3255)-5_bsz067n06ls-png
4 phase:
LTC3784 2/4-Phase Boost Converter for up to 55V Output 600/1200W (TPA3251, TPA3255)-14_bsz067n06ls_4ph-png
Initial design parameters:
600W cont. output
1200W peak output (thermally limited)
regulation loop bandwidth > 10kHz
4 phase operation for 12V SLA battery input with up to 30A per phase
2/4 phase operation for voltages greater than 24V like SLA in series or lithium battery packs
100*100mm in size
The PCB is a 4 layer board with 100*100mm in dimension. The design is finished and several use cases are available for simulation in LTSpice and LTpowerCAD.
Motivation:
Even if there are boost converters available for "cheap" from Aliexpress/TaoBao/Ebay, these are mainly limited to about 30A cont. input current and single phase (hard switching) with lots of radiated EMI (by design). With 10V input voltage under load, these run out of "ompf" at about 300W input power. The 2/4 phase concept shown here is able to push 30A per phase so 1200W from 10V input should be possible.
Groupbuy intent:
This groupbuy is for a bare PCB with schematics, BOM and assembly instructions. I want to order a minimum of 10pcbs but actually need less so thats where you can jump in.
For the first run i'd order standard 1.6mm, 4 layer, 1oz, green silk board with HASL. The price for one PCB is roughly 7€ then. If there's enough interest, we may order ENIG (2oz.) boards with Red or Blue silkscreen.
International shipping is 4€ untracked or 6.20€ tracked with "Deutsche Post" from Germany.
Risks:
The design is practically untested (as usual for the first run), so their is a small risk that some things need manual patches. Having said that, the implementation is working in simulation (LTSpice, LTpowerCAD), so the chances are high it works out of the box. Things need tweaking are regulation bandwidth and compensation.
I've done several designs for class-D, dsp, audio, etc. in the past, so this is not my first project. You may check on 360customs.de which is my uncommercial build blog.
Best regards,
Christian
LTC3784 2/4-Phase Boost Converter for up to 55V Output 600/1200W (TPA3251, TPA3255)Hide this!Advertise here!
FS: TPA3251 TPA3255 2.0 BTL Amplifier doctormord Swap Meet 11 13th August 2017 07:14 PM
Boost Converter w/ positive AND negative output payloadde Power Supplies 11 11th October 2015 07:49 PM
Boost converter JungleVip Power Supplies 7 26th March 2012 11:48 PM
Calculations for 2ohm into 1200w @ a 60 degree load phase angle. ? Fanuc Solid State 0 26th December 2007 12:25 AM
what use for a boost converter ? Tekko Power Supplies 12 27th December 2006 10:09 AM
