Group Buys Members group buys
GB2 for Pioneer Super Linear Circuit
Old 6th May 2018, 05:22 AM   #11
kartk is offline kartk
passive420 UK - 2 full kits.
sonidos USA
s610adam USA
arnd13 DE
dabore84 NL
mlackey USA
hiker47 NL
kartk India
Total: 9 kits
Old 6th May 2018, 08:06 AM   #12
lydan01 is offline lydan01  Australia
lydan01's Avatar
sonidos USA
s610adam USA
arnd13 DE
dabore84 NL
mlackey USA
hiker47 NL
kartk India
lydan01 Aust
Total: 10 kits
Old 7th May 2018, 04:54 AM   #13
EUVL is offline EUVL  Europe
Thank you for your interest.
We'll leave it open till the end of May.
Patrick
xen-audio.com
Old 7th May 2018, 08:47 AM   #14
Joschl is offline Joschl  Germany
Joschl's Avatar
sonidos USA
s610adam USA
arnd13 DE
dabore84 NL
mlackey USA
hiker47 NL
kartk India
lydan01 Aust
joschl DE
Total: 11 kits
Old 8th May 2018, 12:42 PM   #15
hiker47 is offline hiker47  Netherlands
sonidos USA
s610adam USA
arnd13 DE
dabore84 NL
mlackey USA
hiker47 NL - 2 kits
kartk India
lydan01 Aust
joschl DE
Total: 12 kits
Old 9th May 2018, 01:46 AM   #16
passive420 is offline passive420  United Kingdom
Looking through the BOM for the amp boards and it seems the MMA0204 0.1% MELF resistors in those values are nowhere to be found. Can a standard SMD package such as 1206 fit instead?
RG3216P-5101-B-T1 Susumu | Mouser United Kingdom
BOM: http://xen-audio.com/documents/SLHPA...c%20171005.pdf
Actually looking at data sheets the MELF's are 3.6mm and the 1206's are 3.2mm...
Old 9th May 2018, 05:20 AM   #17
Please ask technical questions here :
The Pioneer Super Linear Circuit
Thx,
Patrick
xen-audio.com
Old 9th May 2018, 12:48 PM   #18
To those on this GB - I can order the MELF resistors as advised by Patrick and would supply the correct qty and values for one stereo amp kit.
Vishay SMD thin-film resistor, 5.1 kΩ (5K1), 0.25 W, TK +-50 MMA 0204-50 BL 1% 5K1 | Burklin Elektronik
Vishay SMD thin-film resistor, 6.2 kΩ (6K2), 0.25 W, TK +-50 MMA 0204-50 BL 1% 6K2 | Burklin Elektronik
Vitrohm SMD metal film resistor, 1 Ω (1R0), 0.25 W, TK +-50 ZC0204FKE07 1R0 | Burklin Elektronik
4 x 5.1K
4 x 6.2K
4 x 1R
Or I can just order enough for the European participants. If everyone is interested we can wait until the GB has reached the required number.
Old 9th May 2018, 03:22 PM   #19
You should always order extra SMD parts, just in case.
In quantities they cost nothing.
If you drop one and cannot find it on your carpet, you are stuck.
And always keep some for repair.
(I normally order at least 10 pcs.)
Patrick
xen-audio.com
Old 9th May 2018, 03:43 PM   #20
One more thing I should mention.
The updated design document with BoM will only be sent to you after you have confirmed that the PCBs have arrived.
The pdf files published here at the forum do not necessarily contain the most up-to-date information.
This applies equally to the amplifier, the regulators, the cross feed, and the protection board.
Patrick
xen-audio.com
GB2 for Pioneer Super Linear CircuitHide this!Advertise here!
The Pioneer Super Linear Circuit EUVL Headphone Systems 193 10th June 2018 03:24 PM
Interest for Potential GB for Pioneer Super Linear Circuit EUVL Group Buys 244 5th May 2018 04:46 AM
The Tubecad Super-Simple, Super-Fine FET Circuit in HPA Configuartion EUVL Headphone Systems 10 10th January 2018 04:20 PM
AES E-Library: Super Linear Circuit by Ozawa, Okio; Ishikawa, Kikuo aparatusonitus Solid State 16 17th January 2012 09:49 AM
