MOX-like crossover and discrete opamp group buy - Page 9 - diyAudio
Go Back   Home > Forums > Commercial Sector > Group Buys
Group Buys Members group buys
Old 28th April 2004, 02:52 PM   #81
tiroth is offline tiroth  United States
They are still recommending it for new designs. This was posted just over a week ago.
http://www.semicon.toshiba.co.jp/sol.../poweramp.html
Old 28th April 2004, 04:08 PM   #82
MBK is offline MBK  Singapore
I wouldn't be surprised if the 2sk389 was in fact alive and kicking. Whatever they tell me here I take it with a grain of salt. The English is not always the best, and rather than embarrassing themselves in attempting to describe a complicated situation they just cut it short and say "discontinued".
FWIW - what other transistors are a close match to the 2sk389? Maybe I can get an equivalent type locally. It's always nicer to play around with stuff that can be replaced easily in case of crash'n'burn
Old 29th April 2004, 04:55 AM   #83
It works.
The MOX board is good to go. I won't have the discrete opamps verified until tomorrow as I...mmm...blew up the only one I built so far.
Note: the LP filter appears to cut off after 10k, but this is simply crosstalk in my soundcard.
Old 29th April 2004, 05:20 AM   #84
tool49 is offline tool49  Canada
tool49's Avatar
Looks very nice, would you mind giving us a bit more info about the graph? What were the curve chosen, the Q of the filters, the target frequencies, etc...
Also why is the level at -10? What was the gain configured in the buffers?
Thanks!
Sébastien
Old 29th April 2004, 09:06 AM   #85
moamps is offline moamps  Croatia
Originally posted by tiroth
It works.
very nice work.
I won't have the discrete opamps verified until tomorrow as I...mmm...blew up the only one I built so far. [/B]
Problem is maybe wrong BJT's orientation if you are using MPSA42 and 92.
Old 29th April 2004, 01:45 PM   #86
Dimensions
The completed dual opamps have a footprint that is just about exactly .930x.930", or about 23.6mm square.
They stand 1.45" (37mm) tall, plus another .1" (2.5mm) if you use the headers I used.
The total height of a MOX board populated with opamps is about 2.25" (57mm), less depending on your use of sockets, etc.
Graph
The graph shows the curves for HP and LP @ 2kHz with Q of 0.5, 0.7, 1.4, 1.7 (on the HP).
Don't pay attention to the absolute gain; I needed enough headroom to show the high Q peaking.
Opamp
Moamps, I have the sinking feeling that you are right. I traced my layout against yours, not thinking that your red traces were problably bottom signal for a single layer board.
Time to fix.
Old 29th April 2004, 03:01 PM   #87
EDIT: The Q values I listed may be wrong. It was rather late last night when I finally got to tracing the curves and I replied from memory. Comprehensive tests are coming tonight.
Old 29th April 2004, 03:01 PM   #88
.....not thinking that your red traces were problably bottom signal for a single layer board. ...[/B]
It's my fault too, sorry. OPAMP PCB is designed at the first time for BC550C and BC560C (diferent pinning). MPSA transistors are later placed on board (mirrored), but I didn't made changes on PCB board picture I published in MOX thread.
Old 29th April 2004, 03:10 PM   #89
How about leaving it as is and using BC550/560?
Old 29th April 2004, 03:53 PM   #90
diyAudio Moderator Emeritus
roddyama's Avatar
I hope we can go with the MPSA 42 and 92 since I already have a stock just for this project.
BTW, that was what was shown in Moamp's original schematic.
Rodd Yamashita
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
990 discrete opamp udip Solid State 18 13th February 2009 12:00 AM
My discrete opamp udip Solid State 51 8th August 2006 08:33 AM
Copyright ©1999-2017 diyAudio
