Group Buys Members group buys
Official GB for DSD DAC Signalyst DSCv2
Old Yesterday, 04:32 PM   #321
Vit123 is offline Vit123  Russian Federation
Yes, on 2.6.2 Amanero connector is rotated by 180 degrees. Pin 1 on Amanero board must match witn Pin 1 on DSC.
GB DSC Signalyst v2 DSD DAC
Old Yesterday, 06:08 PM   #322
miksi is online now miksi  Serbia
Thanks Vit, you were right. I did download luchoh update and unpacked it but forgot to install. This linux commands can be really tricky when you have some other distraction...
Old Yesterday, 06:21 PM   #323
barrows is offline barrows
Default Thanks...
Thought so but wanted to be sure. Drat, got a defective SingXer C-1, no DSD lock on USB signal (filckering DSD LED on interface).
Old Yesterday, 11:36 PM   #324
Default Yes...
On Singxer C-1 interface, pin 1 is mis-marked to the opposite end from Amanero. I realized this by seeing where the 3.3 VDC output was.
Another note for V. 2.6.2, with Lundhall 1527XL, the jumpers J10-11 are irrelevant as far as I can tell, as they just connect XLR pin 1 to Chinese tranny center tap position. Ground as to XLR is left floating in this case. I think my approach for G would be to connect pin 1 XLR to chassis, and ground from the 2.6.2 board to chassis (perhaps via a switch). G on the PCB also connects to the Lundhall case and static shield, so it probably should be connect to chassis ground, and therefore XLR pin 1.
Old Today, 08:32 PM   #325
Default Curious...
I am measuring only .74 V output (before transformer) at 0 dB level? I made sure DSD oversampling level reduction (for safe oversampling, usually set -3 to -5 dB) was at 0 dB attenuation for this measurement. Both channels measure the same. My understanding is that the output should be ~1.6 V.
I am going to need to add a gain stage for my purposes even at 1.6 V out, but I really want this DAC to achieve it's specified output?
Official GB for DSD DAC Signalyst DSCv2Hide this!Advertise here!
Signalyst DSC1 mcluxun Digital Line Level 979 Yesterday 08:56 PM
Official M2 schematic Nelson Pass Pass Labs 2807 11th July 2018 10:24 AM
Signalyst DSC-1 Kit - DSD Decoder nautibuoy Swap Meet 2 4th October 2016 07:04 PM
