Group Buys Members group buys
Official GB for DSD DAC Signalyst DSCv2
Old 11th July 2018, 11:44 AM   #301
2A3SET is offline 2A3SET  Canada
Originally Posted by pinnocchio View Post
This spec sheet is the old 400. The P400 has 256 CUDA cores and I believe 3x DP, but since it is a real Xeon server, I’m not connecting any display on it.
Do
I meant DP for double precision, there is no such performance data for P400 so probably 1/32 of the SP.
IMHO you need the FP64 function to assist the HQplayer cuda offload.
By the way there are still some Tesla K20X left on the bay, $150 only.
Old 11th July 2018, 12:26 PM   #302
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
They require CUDA compute level 3+ for their software. The P400 has level 6 but I’ll look into the K20x
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 12th July 2018, 01:25 PM   #303
Mark Verhoeven is offline Mark Verhoeven  Netherlands
My DSC is coming soon. I have a question, would like to feed it with DSD256, but I only am able to connect it via USB from my Mac Mini. As far as I could see, Amanero and Mac only can do DSD128. Is there an other solution other than buying Windows PC? Or isn't there much SQ difference between PCM upsampled to 128 or 256?
Thanks,
Mark.
Old 12th July 2018, 03:02 PM   #304
Vit123 is offline Vit123  Russian Federation
Mark, if you are with HQP or Roon, the easiest way is to use any ARM device as a NAA /Roon Bridge under Linux (RPI, Odroid ...). It supports up to DSD512 and costs ~ 50 USD.
GB DSC Signalyst v2 DSD DAC
Old 12th July 2018, 08:15 PM   #305
ecata is offline ecata  Italy
Originally Posted by ferrilu1 View Post
Hello very nice build, SQ description? what did you use previously to listen dsd?
thanks
gianluca
dac SMSL8 with ess9018k2m
Old 12th July 2018, 08:29 PM   #306
Thanks Vit, I own a Allo Usbridge, that should also work, isn't it? Sorry for my questions, but I never have used the Allo... So with such device I connect to Amanero via USB? Isn't there a device which can connect via I2s directly with DCS, or do you miss the mute function in this situation?
Old 13th July 2018, 08:19 AM   #307
Heard many good reviews about Allo Usbridge. It should work:
1. Install DietPi on Allo Sparky.
2. Login to Sparky and run software configuration utility.
3. Install NAA.
4. Connect Amanero to Usbridge.
5. Start HQP on your Mac. HQP-Settings - choose NAA and Amanero.
That's all.
As I know DSD Native through I2S is not supported in Sparky/USBBridge. So you can't connect it to DSC directly.
Old 13th July 2018, 09:53 AM   #308
ferrilu1 is offline ferrilu1  Italy
A consistent improvement?
Old 16th July 2018, 11:05 AM   #309
3. Install NAA.
That's all.
Another device you know of which can connect via LAN with my Roon server and can output I2S to the DSC? I have a Metrum Ambre on order, but I don't think it will do DSD Native at all…. I will use it with my other DAC, the Metrum Jade via I2S.
Thanks,
Mark.
Old 16th July 2018, 01:05 PM   #310
Mark, I know the only one ARM device capable of DSD152 Native over I2S - BeagleBone Black (BBB) with Botic kernel.
Maybe someone will be able to add another.
Official GB for DSD DAC Signalyst DSCv2Hide this!Advertise here!
Official M2 schematic Nelson Pass Pass Labs 2827 Today 08:32 PM
Signalyst DSC1 mcluxun Digital Line Level 979 18th July 2018 08:56 PM
Signalyst DSC-1 Kit - DSD Decoder nautibuoy Swap Meet 2 4th October 2016 07:04 PM
