Group Buys Members group buys
EU: Router circle jig 56mm-420mm in 1mm step
Old 5th March 2018, 04:10 PM   #11
Mario Pankov is offline Mario Pankov  Europe
Originally Posted by jcastellano View Post
Iím interested as I have the same issue with the Jasper being in inches.
Jorge
Hi Jorge,
can you forward a copy of the base of your router?
Can we agree on the material too (that`s to all interested), I will phone the laser facility in a few days, I need to add the lines for easier navigation.
1. POM
2. Aluminium alloy
Old 5th March 2018, 06:43 PM   #12
jcastellano is offline jcastellano  Spain
Default I have also the Bosch
Originally Posted by Mario Pankov View Post
Hi Jorge,
1. POM
2. Aluminium alloy
Hi Mario,
I also have a Bosch router, mine is POF1200AE but has the same base as the POF1400ACE.
I am in doubt about the material, I use the jig barely, once in two years more or less...so I am not concerned about being durable...so just to make a decision, I would prefer aluminium. But if the rest of the groupbuy chooses the POM...itís ok for me.
Jorge
Old 5th March 2018, 06:49 PM   #13
I am more inclined to aluminium too, POM cannot be etched so no writings on it, only engraving. I think aluminium would be better off.
Old 18th March 2018, 10:08 AM   #14
heinz1964 is offline heinz1964  Denmark
Default Any news
Hi
Any news on this group buy?
It does not matter to me if it is aluminium or POM.
best regards
uwe
Old 18th March 2018, 10:20 AM   #15
raelman is offline raelman  Spain
+1 interested.
Old 18th March 2018, 11:51 AM   #16
Yes, I will ask for final quotes tomorrow. Then will post here and we can setup the order. I got the POF1200 base drawing so will add it later today.
Old 18th March 2018, 01:59 PM   #17
Forane12 is offline Forane12  Bulgaria
+1
Old 20th March 2018, 04:58 AM   #18
The POF1200 file Nisbeth was kind enough to send me was not downloadable by some reason. He`d resend it today so hopefully tomorrow I will send the final design for pricing.
Old 22nd March 2018, 06:38 AM   #19
v is offline v  Denmark
Hi Mario
This is super,
i am in, for one as well.
I have the Bosch
BR Henrik
Old 22nd March 2018, 07:55 AM   #20
I don`t know if we can make 7, give me a chance to check it. Chance is I will make 8 so one will go on sale here or on ebay. I will let you know today, Henrik.
It takes a bit longer - I had to have this jig with my by the weekend but I need to visit a local Bauhaus and confirm the design fits exactly the Bosch models. Nisbeth sent me a scan and two rullers for scaling but I want to verify and I will do it today. This evening I will apply any adjustments to the files if needed (depends on how well it fits the actual POF1200) and will forward the file to several companies to gather offers.
The aluminium type would be 5083. It is among the strongest (without quenching, which may also cause the material to bend) and has good anodizing properties. Some of the strong types are not very accommodative to anodization so it has to be 5083. I used makeitfrom.com for comparison and some university research on chemical and corrosion resistance. 2024 has slightly higher Brinell strength but is not as easy to anodize and is very susceptible to chemicals. 5083 is considered marine grade and has excellent chemical and corrosion resistance at the cost of slightly reduced strength. However, it can receive deeper anodizing which I believe will make ti even stronger than the 2024 which appears to form very thin anodizing layer. 7075 was the best but it cannot be anodized and has copper and zinc which make it more reactive to some chemicals.
EU: Router circle jig 56mm-420mm in 1mm stepHide this!Advertise here!
Speaker Enclosure -Bare Basic Router Bits & Bobs needed for Circle Cuts, Flush Mount Pippi Lindenstroem Construction Tips 5 12th August 2017 12:54 PM
Custom Circle Jig for Dewalt Compact Router brettntc Construction Tips 10 20th March 2015 03:10 AM
small hole circle router jig, with pictures tinitus Equipment & Tools 20 14th January 2013 09:49 AM
WANTED: 56mm ID port peterpan Multi-Way 8 25th November 2003 05:30 AM
FS: Plunge router and Jasper circle jig bsteeves Swap Meet 7 18th June 2003 05:29 PM
