Group Buys Members group buys
Pure Evoke/Avanti Flow - New Display Module
Old 15th December 2017, 08:00 PM   #21
Titanium rider is offline Titanium rider
Displays received and one fitted, working perfectly. Thanks AJSDyno for your help.
Fitting was generally without problems following the two explanations given in the earlier thread. Two points though:
1. On my Flow the screen retainer was sealed on three sides to the radio faceplate. I removed it to enable access to the display. Any thoughts on the need and best method to re-seal it?
2. The first time I fitted the new display it did not work. The problem was that the copper shield and therefore also the guide slot were not quite central on the new display. As a result, the ribbon was slightly askew when entering the connector. Re-positioning the shield solved the problem so it's worth carefully checking the position of the guide slot when re-fitting the shield.
Old 17th December 2017, 05:23 PM   #22
AJSDyno is offline AJSDyno
Pure Evoke Display Supplier
Glad it's working!
I don't know about resealing the screen retainer, mine was only held on with tiny screws - no sticky stuff or seal.
Good point about the connector, they don't have much latitude so need to be aligned properly to ensure a good connection.
Old 17th December 2017, 09:07 PM   #23
DarkMatter3 is offline DarkMatter3  United Kingdom
I came across this forum while researching my very dim Avanti Flow display. It seems a shame that Pure is being less than helpful as I still use my Avanti on a daily basis.
If you have any displays left or are making another order, I would like to order one please?
Hopefully they aren't too hard to change!
Old 17th December 2017, 10:12 PM   #24
There are some available, I have sent you a PM.
Old 18th December 2017, 08:28 AM   #25
Hi, I will definitely have one off you, canít see anything in my PM box though?
Old 18th December 2017, 10:21 AM   #26
I have sent you a Paypal payment for the display, have a great Xmas
Steve
Old 18th December 2017, 12:29 PM   #27
Steve
Got it - thanks. I'll post out today.
Cheers!
Old 19th December 2017, 12:19 PM   #28
noigardo is offline noigardo
Got my screen yesterday. Took the 15 minutes fitting it. Am now enjoying a like new Pure Evoke. Thank you Adrian for letting DAB+ / internet radio into our otherwise sorrow Christmas. Niels
Old 19th December 2017, 08:26 PM   #29
xtof41 is offline xtof41  Belgium
Default Screen received - Radio like new !
+1
Thank you very much, AJSDyno - Everybody should be good people like you
Old 20th December 2017, 03:05 PM   #30
Badger1 is offline Badger1
Screens arrived this afternoon and fitted......radio back in use and Glory shines around.
Many thanks AJSDYNO for sourcing these. All the best.
Pure Evoke/Avanti Flow - New Display ModuleHide this!Advertise here!
Pure Evoke-3 radio MikeVou Everything Else 3 21st April 2018 07:46 AM
display module needed hitsware Parts 0 26th July 2016 01:53 AM
PURE DAB Tuner DRX-701ES display brightness dynoPort Digital Source 2 23rd November 2011 02:38 PM
Which company produce high end pure digital amp module? mbl Class D 0 3rd March 2010 06:44 PM
