Group Buys Members group buys
Group buy: SSR03 Super Regulator Power Supply Board
Old 25th April 2018, 08:50 AM   #191
fred sonnen is offline fred sonnen  Germany
317, plan view, from right to left, with installed load resistors
4,41
5,47
5,08
337, plan view, from right to left,with installed load resistors
5,45
7,38
4,88
Old 25th April 2018, 12:23 PM   #192
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
You should have 10 volts at least and the real value is only 5,4 volts
Do you have 2,2 ohm at R1-R10?
Can you please check:
AC voltage between X1, 1 and X1,2?
DC voltage from both sides of R9 down to ground?
Maybe your R1-R10 has to high values for your needs.
/Per-Anders (my first name) or P-A as my friends call me.
Sign up for interest HERE. 4 pcb's in order. 0 paid.
Old 25th April 2018, 12:53 PM   #193
load resistors installed
I do measure 2,4-2,5 ohm at R1-10. In installed condition.
AC1+2 are 8,5V AC
AC1 - AC2-gnd and vis versa is also 8,5V AC
8,28V R9 7,28V DC
Old 25th April 2018, 04:53 PM   #194
peranders's Avatar
The series resistors are a bit too high when you have 8,5 VAC in. Try to reduce R1-R8 to 1 ohm. If that doesn't help reduce R9 and R10 also.
Old 26th April 2018, 04:19 PM   #195
Bought 1ohms Burt measured 1,2ohms...
Installed one side R4-10, measured 4,2v@x3
Second side just r5+7, measured 3,6v@x3
Load resistors installed
Old 26th April 2018, 05:09 PM   #196
peranders's Avatar
What are the voltages on both sides of R9 and R10? Do you have 1 ohm on all positions?
Old 26th April 2018, 05:42 PM   #197
8,22. R10 (2,2ohm) 7,39
8,4 R9 (1,2) 7,93
Except r10 all the rest is 1,2ohm
Old 26th April 2018, 05:54 PM   #198
peranders's Avatar
Try to short all resistors. You must have 10 volts in as a minimum.
Old 26th April 2018, 06:09 PM   #199
Don not get it wrong. The 10V findings are now a few weeks too late. I was afraid of that during the last few days.... Before I ordered this individuall made transformer, I asked you about it. You said 9V are OK. Well, it's 8.5V now...
The resistances, as they are given, certainly have a meaning? Is shorting all resistors to get a result? Or are the parts on the place not this important?
Old 26th April 2018, 06:25 PM   #200
peranders's Avatar
The resistors are for reducing harmonics. Normally you don't have any but this is a super regulator with ultra smooth raw voltage.
Group buy: SSR03 Super Regulator Power Supply BoardHide this!Advertise here!
Group Buy: SSR03 Super Regulator Power Supply peranders Group Buys 406 28th March 2018 10:21 PM
High quality PCB board for amplifier power supply - group buy supernet Group Buys 43 12th October 2015 07:22 PM
Opamp power supply, super regulator alternatives? imperfectcircle Power Supplies 33 3rd May 2007 06:55 PM
super regulator vs a good stiff LCLCLC power supply audionut Parts 4 30th April 2007 07:01 PM
