Group Buys Members group buys
Group buy: SSR03 Super Regulator Power Supply Board
Old 20th April 2018, 06:13 PM   #171
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Which voltage do you have on the right side of R35? The net called VREF. In this point you should have 2.50 V
File Type: png Skärmavbild 2018-04-20 kl. 20.10.36.png (299.1 KB, 69 views)
/Per-Anders (my first name) or P-A as my friends call me.
Sign up for interest HERE. 4 pcb's in order. 0 paid.
Old 20th April 2018, 07:42 PM   #172
fred sonnen is offline fred sonnen  Germany
Originally Posted by peranders View Post
Are the DZ1 and DZ2 oriented in the right direction also? The cathode marking, where do you have it?
is it possible that at position H1+2 I allways get a result?
in one position I get 1770. when I swap the tips I get 720?
At DZ1+2 only in one position I get numbers.
DZ1+2 hase the right polarity
Old 20th April 2018, 07:50 PM   #173
x3-gnd and r35 right is 2,5V on both sides
Old 20th April 2018, 08:27 PM   #174
peranders's Avatar
Good but what about the LED? Do you have it in the right direction? Notice that most LED's has a straight surface at the cathode but some has this between the pins. How many volts do you have across the LED? If you have more than 1.6-1.8 V then you have the LED in the wrong direction. The long pin is anode and the short one cathode but I'll guess you have them cut off already.
Old 21st April 2018, 06:26 AM   #175
peranders's Avatar
You still have
opamp N2
pin 2: 3,69V
pin 3: 3,07V
opamp N1:
pin 2: 3,75V
pin 3: 3,13V
You have 3,07-313 V on the left side of the R35?
Old 21st April 2018, 07:15 AM   #176
Good morning ;-)
I do have R34left 3,03 and R35left 3,09V
R34+35 right 2,51V
N1p2: 3,70
N1p3: 3,07
N2p2: 3,66
N2p3: 3,03
H1+2 I do have 1,6V
DZ1+2 I have 7,8V
just for info: none of the LEDs are on
Old 21st April 2018, 09:18 AM   #177
peranders's Avatar
The LED's are in the wrong direction. Have you checked closely how they should be mounted? See post 167. Consult also the schematic.
Old 22nd April 2018, 07:50 AM   #178
With a hot air dryer it was then no longer soooo difficult to remove.
H1+2 and DZ1+2 should show 1.6V, right?
The cathode (straight surface / short pin) at H1 points inwards. The one from DZ1 to the outside, right?
H2 and DZ2 just the oposite, right?
I may have installed the DZx LEDs upside down again. But I still get 1,6V for Hx and 7V for DZx.... ;-(
sorry for being so complicated...
Old 22nd April 2018, 08:18 AM   #179
peranders's Avatar
It's very good to be sure when you mount a part, not almost sure. Long pin is "plus" or "anode". Compare the pcb layout and the schematics in order to be really sure. Since the pcb only has two layers you can see exactly how it's designed.
The flat surface of the cathode marking shall be in one direction for all LED's.
Notice that you have already succeeded to get this working and by this managed to mount the H1 and H2 correctly. This 5 V version has the DzX changed to LED's so this is the difference. Take one more look into post 167 and look at the picture.
Old 23rd April 2018, 05:46 AM   #180
Am I right that the long legs are always on top of the pictures?
If yes it is more than possible that I have them in the wrong direction...
above H1+2 is shown a "+". for me this is the Anode long leg. That I have.
below the text DZ1+2 is horizontal line. For me that is the cathode / short leg. Wrong?
Group buy: SSR03 Super Regulator Power Supply BoardHide this!Advertise here!
Group Buy: SSR03 Super Regulator Power Supply peranders Group Buys 406 28th March 2018 10:21 PM
High quality PCB board for amplifier power supply - group buy supernet Group Buys 43 12th October 2015 07:22 PM
Opamp power supply, super regulator alternatives? imperfectcircle Power Supplies 33 3rd May 2007 06:55 PM
super regulator vs a good stiff LCLCLC power supply audionut Parts 4 30th April 2007 07:01 PM
