Group Buys Members group buys
Group buy: SSR03 Super Regulator Power Supply Board
Old 17th April 2018, 05:18 PM   #161
fred sonnen is offline fred sonnen  Germany
I exchanged R38, R40, R44, R46
first SSR03-17V is now comparable to the second SSR03-17V
including the numbers with load restistors: + -14,7 V at X3 measured parallel to the resistors
As said before: The ssr03 should deliver 400mA@17V
Old 17th April 2018, 05:51 PM   #162
and now the SSR03-5V: (TT is delivering 9V)
none (!) of the four LED are on
tin drops on J1-J4: YES
X3: no load resistor parallel installed
+ -> gnd: 8,90V DC
- -> gnd: 8,68V DC
opamp N2: results in DC
counting order: dot is 1, then going down the side =4; other side 5, going up=8
the second measuring tip is at X3-gnd;
pin 2: 3,69V
pin 3: 3,07V
pin 4: 9,42V
pin 6: 1,06V
pin 7: 0 V
opamp N1:
pin 2: 3,75V
pin 3: 3,13V
pin 4: 0
pin 6: 1,01V
pin 7: 9,75 V
Old 18th April 2018, 04:32 AM   #163
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
... and as I told you, you must adjust the current limit since it's set to 300 mA. I recommend that you check the real consumption first.
/Per-Anders (my first name) or P-A as my friends call me.
Sign up for interest HERE. 4 pcb's in order. 0 paid.
Old 18th April 2018, 04:36 AM   #164
peranders's Avatar
The 5 V regulator shall have 2.5 volts on the pin 3.
Is the LED in the DZ1, DZ2 position in the right direction?
Old 18th April 2018, 05:11 AM   #165
I don't have any measured values yet, because I need a working power supply. ;-)
This is what I have from the DCG3 designer Salsa:
"The DCG3 can go 300mA pk per channel at +/-17V. In other words 10W pk power ch i.e. 5W pk power each rail worst case draw in high bias (Ib 150mA) builds."
My understanding is 300mA@17V + 50mA for a AMB "epsilon12" protection board.
To test the PSU in advance I bought the 47ohm load resistors.
Old 20th April 2018, 08:10 AM   #166
I have the impression that you may have to iteratively hit exactly the point where V and mA macht your requirements?
If so, to work with the mentioned 350 - 400mA@17V is not sufficient?
How do I get on here?
How do I get these 2,V on pin3?
Are there any other measurement that I can deliver to you to fix this?
I hope I did the LED's right... How do I check this now?
Old 20th April 2018, 10:20 AM   #167
peranders's Avatar
You can test the LED using diode test on your DVM. Make sure the regulator is unpowered. Compare the schematic symbol. See the picture. With diode test you should have a weak light from the LED. The cathode shall be facing down.
Old 20th April 2018, 10:26 AM   #168
peranders's Avatar
The current limitation must be set to cover your needs. R47 and R48 must be tuned. 0.65/I = R
350 mA = 1.8 ohm
If you solder 12 ohms in parallel, then you will have 1.8 ohms. You can remove the 2.2 ohm and replace it with 1.8 ohm but the risk is that you will damage the pcb.
Old 20th April 2018, 12:03 PM   #169
I do have one LED left: results with the DVM: 1770
When changing from DZx to Hx, I have to swapp the measuring tips.
When changing from DZ1 to DZ2 or H1 to H2, I do not have to swapp the measuring tips.
build in H1: 720
build in DZ1: 1650
build in H2: 720
build in DZ2: 1650
Old 20th April 2018, 01:32 PM   #170
peranders's Avatar
Are the DZ1 and DZ2 oriented in the right direction also? The cathode marking, where do you have it?
Group buy: SSR03 Super Regulator Power Supply BoardHide this!Advertise here!
Group Buy: SSR03 Super Regulator Power Supply peranders Group Buys 406 28th March 2018 10:21 PM
High quality PCB board for amplifier power supply - group buy supernet Group Buys 43 12th October 2015 07:22 PM
Opamp power supply, super regulator alternatives? imperfectcircle Power Supplies 33 3rd May 2007 06:55 PM
super regulator vs a good stiff LCLCLC power supply audionut Parts 4 30th April 2007 07:01 PM
