Group Buys Members group buys
Folsom DIY7297 Amp & Antipole PSU
Old 14th October 2017, 08:57 AM   #111
KaffiMann is offline KaffiMann  Norway
KaffiMann's Avatar
Location: Grua, ten minute walk from 60.258792, 10.664731
I ordered all the parts a while back, and seeing that some where not immediately available I just thought "what the heck, there's too much to do anyway." So I'll get them beginning of next year. It also gives me some time to get the rest of the signal chain prepared, looking around at op amps for a pre stage just because I want to. Speakers have not arrived yet either. Will post when there's any progress on the amp.
Edit:
How are they on 4ohm loads?
Old 14th October 2017, 04:32 PM   #112
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
4ohm is just fine
Old 15th October 2017, 09:30 AM   #113
lucylu is offline lucylu  England
I have 4 nichicon kg 10,000 50v nice and new would these work ok in the psu instead
Old 15th October 2017, 06:54 PM   #114
That would be fine
Old 16th October 2017, 02:20 PM   #115
pistollero is offline pistollero  Portugal
Hello i want to test only the antipole... i have the bleed resistor 10k...
How many volts should i read?
Is necessary some load dummy or i just measure the output on pcb?
Another thing about the input bypass caps. Are really necessary?
Old 16th October 2017, 04:36 PM   #116
You can test the antipole with no load. Just make sure that the voltage on it is down to nothing when you connect it to amplifier.
Voltage depends on the transformer used. If you have 15-16v transformer you should get 21-24v range.
Input bypass capacitors on the bottom of the board? No, not required.
Old 1st November 2017, 03:46 PM   #117
Hello Jeremy i have amp running. Everything is ok but i ear a lot of noise floor on my speakers like shxeeeeee behind the music..and at lower volumes..
Is it normal?
I have other amps and i dont ear it so louder.
The sound is great
Old 1st November 2017, 03:55 PM   #118
some pics im using ft3 teflon on input caps
Old 1st November 2017, 05:26 PM   #119
You should hear nothing more than a small whisper when your ear is right at the speaker.
If you can hear it where you are sitting, it's excessive.
Old 2nd November 2017, 08:07 AM   #120
It is working good now..
Folsom DIY7297 Amp & Antipole PSUHide this!Advertise here!
FS: DIY7297 w/transistor & Antipole PSU PCB's Destroyer OS Swap Meet 2 3rd April 2016 05:50 PM
Beginners PSU bridge question, building external psu for power amp Deaf Cat Power Supplies 12 13th March 2016 02:37 PM
FS: DIY7297 (TDA7297) & Antipole PSU PCB's Destroyer OS Swap Meet 3 5th December 2015 07:10 PM
SOHA Amp & PSU Layout, need feedback trip-pcs Tubes / Valves 5 22nd August 2007 04:48 PM
WIll an X-PSU v1 power an SI T-amp &/or TC754 pre-amp? gnostic19 Class D 7 3rd August 2007 01:26 AM
